Spending $6000 yes or no ?
Hey guys upgrading my IS250 RWD , My other car is a G37 AWD.
Any known problems to look for before I buy my first 2009 GS350 AWD?
Fully loaded Top of the Line Package, Excellent Condition, No Accidents, AWD, 2 sets of tires on rims (winter/all season), Rear Camera, Rear Privacy Shade, Heated & Power Memory Leather Heated and Cooled/Vented Seats, Sunroof, Touchscreen Command, Bluetooth, Power Windows, Keyless Entry, Cruise Control, ABS, Air Conditioning
Go for it, solid cars! If its at 90 or 100k miles make sure the water pump has been changed. If not replace, its a $100 part and about 2 hours to install. Other then that regular maintenance! Good luck!
Depends on the mileage and the wear, but if you are around 100k or more, I'd suggest a few things in addition to your list:
Gas cap
Replace the cooling system pressure cap when replacing the coolant
Check the front suspension's lower control arm rear bushings -- worn bushings here will cause accelerated tire wear -- consider GS-F or aftermarket (RR-racing or FIGS?) LCA rear bushings
Clean the moonroof drains
Not sure if it's a 4GS problem too, but maybe check the AC drain tube or grommet
PCV valve
Check alternator and battery
Serpentine belt
Lube the rear brake caliper slides
Exterior detail including iron removal, clay bar, and some sort of coating
Lubricate the moonroof and sun shade slides
Replace headlight bulbs (especially halogens which lose light output over time)
Gas cap
PCV valve
Serpentine belt
joedaddy1
Jan 3, 2016 08:51 PM
NikonGuy
Sep 3, 2014 09:40 PM
Stealth.GS
May 6, 2008 04:26 PM
