Ignition Coil Replacement
Old Aug 24, 2019 | 02:05 PM
nchauh's Avatar
nchauh
Default Ignition Coil Replacement
Hello fellow GS300 drivers,
I plan to change the spark plugs on my 06 gs300. Was wondering if it was necessary to change the ignition coils too. Car has about 150k miles. I believe that the initial ignition coils are still in there. Previously the spark plugs had been changed by the dealer. Thanks in advance for your help.
Old Aug 24, 2019 | 03:18 PM
ibidu1's Avatar
ibidu1
oem are durable and last long, if youre not having issue with them then leave them. Not worth replacing them with chinese junk
Old Aug 24, 2019 | 05:57 PM
RXGS's Avatar
RXGS
Don’t replace unless you have a problem. In 170k I only replaced cylinder 5 coil because of a misfire and I wasn’t sure if it was the plug or the coil, so when changing all the plugs I changed the coil as well
rabidwhale
Jan 13, 2025 11:07 AM
halloo
Feb 3, 2022 08:07 PM
Puttster
RX - 1st Gen (1999-2003)
Mar 6, 2018 07:29 PM
Jay21
Nov 20, 2015 11:01 PM
LexBrett
Apr 25, 2013 05:19 AM
