VSC warning light on
Old Jan 24, 2020 | 01:05 AM
ibidu1's Avatar
ibidu1
Ya, I would suspect the contact cleaner in the wires aswell. Also check the seals on the connectors at times when you remove plugs they unseat themselves. Also I would test the alternator output with a voltmeter just to verify the alternator is pumping over 13 volts while running at idle.
Old Jan 24, 2020 | 01:09 AM
bk300's Avatar
bk300
Thanks ibidu1, I will go through this checklist and get back with you in a few days. If you (or anybody) think of anything else to check let me know, I will try anything once.
Old Feb 9, 2020 | 10:36 AM
bk300's Avatar
bk300
Update for everyone:
My problem was caused by a loose wire to a pigtail, I found a wiring harness and when I tugged at the 2 wires coming out of the harness, one came out very easily. After a temporary repair, the check engine light went away and the car is functioning perfectly once again. I plan on getting a new harness and splicing it into position and that will solve my problem. Thanks for the tips Ibidu1.
Old Feb 9, 2020 | 11:16 AM
ibidu1's Avatar
ibidu1
I'm glad you figured it out and got it sorted. Ya, its not good to tug on wire to unplug harness. But good news its easily fixable, just slide the metal back into the terminal connection and make sure it locks into place. You do not need to replace the wire harness if just a wire pop out. If the metal is damaged and you are not able to fix it, they do sell just the metal pins and you can snip the old wire and crimp on the new metal pin.
mrcouser
GX - 1st Gen (2003-2009)
Apr 12, 2024 09:10 AM
KDHarbour
Apr 26, 2021 10:44 AM
jknoxxx
Oct 3, 2017 09:48 PM
Creamer60
Aug 6, 2017 10:22 AM
kevin11635
Maintenance
Oct 4, 2015 07:51 AM
