Finnicky Cruise Control
Old Jun 23, 2019 | 05:25 PM
Kton's Avatar
Kton
Default Finnicky Cruise Control
I am driving a 2006 GS 430 with Dynamic Radar Cruise Control.
Lately, the cruise has been very finncky. Sometimes it turns on, and sometimes it does not. If it does turn on though, it works perfectly (slows down and detects cars ahead, steady speed).
I should note that these issues started after I attempted (and failed) to remove the front bumper. Could I have loosened a ground wire or something? I didn't touch the millimeter radar, and I don't think there's anything critical to the cruise control in the front bumper area.
Checked for engine codes and nothing pops up aside from TPMS. Anyone else had this issue?
Old Jun 24, 2019 | 08:01 PM
MX73's Avatar
MX73
Check the front emblem. It houses the radar cruise control.
Old Jun 24, 2019 | 08:58 PM
Kton's Avatar
Kton
I checked it already. The radar is actually not in the emblem. The emblem is just a semi transparent plastic cover that is like 3 inches removed from the actual millimeter radar, completely separate and in its own bracket (which I didn't touch or adjust).
Old Jun 27, 2019 | 04:42 PM
enshiu's Avatar
enshiu
Did you replace the fuse of the cruise control. Mine was corroded.
Old Jun 27, 2019 | 05:30 PM
Kton's Avatar
Kton
No I did not. Where is the fuse located? Interior? Exterior?
Old Jun 27, 2019 | 11:44 PM
tghw's Avatar
tghw
It could be something as simple as a flakey, intermittent switch on the steering wheel.
Old Jun 29, 2019 | 09:35 PM
Kton's Avatar
Kton
So I've narrowed it down to a few possibilities:
1. Fuse
2. Cruise Control Stalk
3. Deteriorated Battery (due for a change)
How would I be able to diagnose and single out the issue?
Old Jul 1, 2019 | 07:24 AM
FLYIN4D's Avatar
FLYIN4D
Mine worked great. No longer have it
Old Jul 7, 2019 | 11:31 AM
Kton's Avatar
Kton
Found the culprit: clock spring in the steering wheel.
Hope this helps someone in the future
Old Jul 7, 2019 | 02:15 PM
tghw's Avatar
tghw
What did the clock spring have to do with the cruise control? Those are two completely independent systems.
Old Jul 7, 2019 | 02:25 PM
mspearl95's Avatar
mspearl95
The DRCC controls are on the steering wheel.
Old Jul 7, 2019 | 02:28 PM
tghw's Avatar
tghw
I understand that, but the clock spring is part of the SRS airbag system. It has nothing to do with the cruise control circuits so how did it cause your problem?
Old Jul 7, 2019 | 02:35 PM
mspearl95's Avatar
mspearl95
Clock spring isn’t just for the air bag. I had a Dodge Ram with a broken clock spring, and in addition to the air bag, I also lost horn and cruise control.
Old Jul 7, 2019 | 07:22 PM
Kton's Avatar
Kton
Yep. Clock sprig connects all steering wheel buttons to the rest of the car. Usually the first to go is the horn and airbag, In my case, it is the cruise control.
Moogy
Feb 16, 2026 04:03 PM
93SC300.
Aug 28, 2020 08:10 PM
propcop
Jul 10, 2015 10:26 AM
jcord51
May 17, 2011 09:09 AM
Fly_GQ_4u
Nov 6, 2008 09:26 PM
