Why does this car do this to itself?
Old Mar 5, 2019 | 05:53 AM
kenne01l's Avatar
kenne01l
Default Why does this car do this to itself?
Drove my 06 GS430 yesterday and nearly got into an accident because all these light came on and my car basically just went limp and i could barely stop it. Turns out only issue was the brake fluid was at the minimum level in the reservoir. Topped it up and now its perfect. Is it normal for these cars to do that if the brake fluid isnt even low just needing a top off? Seems pretty unsafe to just go limp like that in rush hour. Is there something else that could be failing that brake fluid being a little low like that?
Old Mar 5, 2019 | 09:56 AM
Propulsion's Avatar
Propulsion
Never heard of this issue being caused by the brake fluid alone. But thanks for the reminder to check my fluids
Old Mar 5, 2019 | 10:09 AM
RXGS's Avatar
RXGS
May have to do with the brake master cylinder ? I know that V8 models and hybrid GSs have a different system from the V6 models that provides “better” braking, but have some cases of documented failure
Old Mar 5, 2019 | 10:47 AM
ibidu1's Avatar
ibidu1
Maybe your brake abs pump is going bad, your car has the GS430/460/450H style abs system that isnt too reliable.
This is what the part is! New they are very expensive close to $2,500
https://www.ebay.com/itm/06-09-LEXUS...275:rk:25:pf:0
Old Mar 6, 2019 | 06:47 AM
kenne01l's Avatar
kenne01l
Yuck, is there a way to know if it is dying on me?
Old Mar 6, 2019 | 12:33 PM
ibidu1's Avatar
ibidu1
On our LS460 they run an identical system, when the brakes went out they would make a clicking sound, eventually the motor overheated and 90% weakend the brakes and pedal was super hard to press.
If only they ran the GS350 style which is totally different and reliable system
shrinkwrap
Feb 9, 2016 05:28 PM
is250Gwong
Apr 24, 2015 05:15 PM
jasone36
Dec 27, 2011 06:29 PM
orangecar
Sep 22, 2007 11:18 AM
