TPMS (Tyre Pressure Monitor System) Nightmare - Help?
If you mess with the system too many times it will go into a lock mode and you will not be able to turn the light off no matter what you do. You need to have a proper scan tool that will perform an ECU reset so that you can reprogram the ECU to accept the new sensors. Also anytime a sensor is replaced the ECU needs to be reprogrammed to accept it. It’s not the type of system that will relearn it will you drive on it’s own
