2006 gs300 awd (help!!)
Old May 16, 2018 | 03:19 AM
Lenny707's Avatar
Lenny707
Default 2006 gs300 awd (help!!)
recently purchased 2006 Lexus GS300 AWD wasn’t working
I changed the battery and put oil in the car and it started up but didn’t sound good. I use the scanner and these came up
(1 code (P0300) Random/ Multiple Cylinder Misfire)
(2-6 code(P0301)Cylinder Misfire Detected)
(7 code (P0356) Ignition Coil F Primary / Secondary Circurt)
(8 code (P0390) Camshaft Position Sensor B Circurt Bank 2)
Anybody have an idea on what I should do, is it an easy fix or should I take it to the shop. I Appreciate any information thank you
Old May 16, 2018 | 06:12 AM
ibidu1's Avatar
ibidu1
Too me it sounds like symptoms of carbon built up cars. The 2006 GS300/is250 have problem with the design of there fuel system. The injectors do not wash the intake valves like a traditional engine. So the intake valves crud up with carbon and it spreads to the rest of the car. If you pop open your intake manifold youll probably see the intake port filled in black soot/carbon. Lexus had a temporary recall on this issue where they rebuilt the engines for free.
Heres what you can do if you diagnosed it as carbon issue. Remove the intake manifold with chemical sprays like berrymans parts cleaner. Spray it inside the runners and with a long hard brush scrub things down. I would also remove the sparkplugs and pour the parts cleaner into the spark plug holes and let it sit for a day. Slap some news plugs and do a seafoam cleaning after and hope for the best
Old May 16, 2018 | 06:33 AM
gs350fan's Avatar
gs350fan
Was the car running fine before?
The last two codes are concerning.
The camshaft sensor could be bad, or the wiring, as well as coil F. I would investigate those. Is Coil F? Cyl 6 I guess coil shorted out or disconnected?
These cars have electrical glitches in the PCM, that may be a reason too.
Old May 16, 2018 | 10:22 AM
Lenny707's Avatar
Lenny707
So I talk to the last owner and he said that it was running fine but that he never check any fluids on the car what so ever. So I’m guessing that had a lot to do with what’s going on.
stirfryboy
Aug 7, 2016 01:47 PM
bdpride04
Nov 13, 2015 08:31 AM
jubay
May 20, 2014 06:44 AM
koosflower
Nov 9, 2008 12:51 AM
