GS460 8 speed auto problem??
Old Apr 30, 2018 | 03:55 AM
Ziggaty's Avatar
Ziggaty
Default GS460 8 speed auto problem??
I have noticed that recently after parking on a steep hill selecting reverse, when the transmission and engine is cold, it slips. Even doing a u-turn drive also slips on this same hill then comes right. I read another thread where someone else experienced this same thing. Is this a common problem, a case of the transmission not being filled properly, transmission oil draining while parked on a steep angle for some time, should I idle for some time to let oil pump its way around first?????? Happy to hear if this a common problem or am I in for a big bill. All your advice gratefully accepted.
BTW This Lexus has a full service history by the dealer and has done 76,000 miles
Old Apr 30, 2018 | 04:04 AM
703's Avatar
703
It shouldn’t slip but when reversing from a incline the transmission will make a clunk sound when you move from P to R.
most likely the wrong fluid is used for it to slip.
Old May 1, 2018 | 09:47 PM
Lukas99GS's Avatar
Lukas99GS
I'm about to hit 200k with my 460 and haven't experienced anything similar, maybe the shop didn't use the correct oem fluid or not the right amount? Maybe go to lexus and have them do it
Old May 6, 2018 | 07:23 AM
snakeo2's Avatar
snakeo2
my next maintenance item is to have my transmission flushed at the Dealer. I'm currently at 108k and everything feels smooth. However, preventive maintenance goes a long way. Those have gone to the dealer, what's a reasonable quote for this job? I've read on other threads that $300 - $500 is what one can expect to pay for a transmission flush on a GS460.
Thanks.
Old May 6, 2018 | 09:28 AM
Fausty's Avatar
Fausty
Thanks.
I didn’t do a flush but rather a drain and fill at a Toyota dealer and it cost me 130 bucks.
Old May 6, 2018 | 01:54 PM
snakeo2's Avatar
snakeo2
@fausty
$130 is not bad at all. I will go to my local Toyota dealer and get this done in the next few weeks. Thanks for the info.
nebodee
RX - 1st Gen (1999-2003)
Sep 20, 2013 03:40 PM
quaiduhm
Mar 27, 2011 10:44 AM
mohep
13
Feb 21, 2011 09:58 PM
Sintari
Sep 15, 2006 09:18 AM
OutlawTita
Maintenance
Dec 2, 2005 03:46 PM
