Mark Levinson pops out!
Old Feb 8, 2018 | 10:14 AM
Rallydakar's Avatar
Rallydakar
Unhappy Mark Levinson pops out!
Hey folks,
I do have an issue on my 450h with ML from 2006...
If I go over volume 30 my Speakers will make an awful pop and stop plaing music but then recover smoothly again - it is a metter of seconds.
I changed my ML Amp with one with 5 channels from a GS 300 - it seemed to work properly but after going on the autobahn it did the exact same thing again!
So I suppose that my old Amp works correctly but I do not know what to do next -
I hope you can help me out , at least you have more experience than here in Germany with ML Systems!
If you already solved a simmilar cause I am really sorry for spamming but I couldnt find something for the GS!
Thanks !
Old Feb 10, 2018 | 09:24 AM
nobelnabil's Avatar
nobelnabil
I am going to give you something to try out. I had a faulty center speaker in my ML system, sometimes when i crank up the volume, all speakers stop working. the way i made sure its not the amp is by changing the speaker balance (in the audio option) and moving the crossed bars in a way to not use the center speaker and since then i didnt have that problem anymore.
now in your situation, start activating only the front speakers (by moving the horizontal bar to the top) and see if you still have a problem, if not then activate the rear speakers only. and keep narrowing what is activated until you know if it is one of your speakers or not. I hope I explained this clearly.
Old Feb 10, 2018 | 10:39 AM
Rallydakar's Avatar
Rallydakar
Hey thank you very much for advising! Didn't thought about that !
Have you repleaced your speaker or just reconnected?
Old Feb 10, 2018 | 01:26 PM
nobelnabil's Avatar
nobelnabil
Well, I disconnected it, it is sitting there unplugged. these speakers are expensive and so far, the sound is great without it. However, I am planning to replace it down the road.
Old Feb 10, 2018 | 03:05 PM
nobelnabil's Avatar
nobelnabil
let us know if you were able to tackle the issue, i ve seen several threads on the same problem as yours and it is good to share your experience to benefit others.
Old Feb 11, 2018 | 06:33 AM
Rallydakar's Avatar
Rallydakar
I will do no worries about that ! Just have to get the time to do it!
Old Jul 9, 2018 | 12:12 PM
Rallydakar's Avatar
Rallydakar
I solved the Problem - it was the Left rear Speaker in the rear shelf . Try & error solved it !
socal28
Mar 26, 2015 04:02 PM
305Busa
Oct 21, 2011 04:54 AM
ballpaulmo
Mar 6, 2010 11:06 AM
tex75021
Jul 23, 2006 04:04 PM
e-man
Mar 27, 2005 12:21 PM
