Personalizing your Lexus DIY
Old Jan 22, 2018 | 02:58 PM
ez12a's Avatar
ez12a
Originally Posted by MX73
Ouch. I order mine from obdii365.com for about $20 bucks. It'll do all the personalized settings and diagnostics but it won't reprogram the ecu, create a new key or register new tpms sensors. I also obtained the latest techstream for my 64bit system.
yeah, i'm **** about getting the latest version of the cable. It was the only one i could find on ebay at least that had a cable running 2.0.4. Mine's advertised to be able to pair new smart keys.
Was a waste of money since I might be getting rid of the car soon anyway haha.
Old Jan 22, 2018 | 03:09 PM
AgedGS's Avatar
AgedGS
Forgive a potentially stupid question here, but I'm intrigued.....the software that comes with the cable is a knockoff of Techstream? or do you need to also source the Toyota proprietary software?
Old Jan 22, 2018 | 03:12 PM
ez12a's Avatar
ez12a
It's a modded techstream software that allows it to work. It's what the dealer uses but with some mods to let it work "offline".
Old Jan 22, 2018 | 03:14 PM
MX73's Avatar
MX73
Side Business! Charge less than the stealership. lol.
Old Jan 22, 2018 | 03:20 PM
AgedGS's Avatar
AgedGS
ok, so the cliffs notes version- win7& up + cable (highest version, highest firmware), and should be all one needs, since the cable comes with the software, correct?
also, any specific options for the hardware that have more functionality, like ecm flash & programming fobs, etc?
Old Jan 22, 2018 | 03:34 PM
MX73's Avatar
MX73
Depending on where you get the cable, it may or may not come with the actual software. It could be the drivers. A quick search around some of the Toyota\Lexus forums can point you in the right direction.
Old Jan 22, 2018 | 03:36 PM
ez12a's Avatar
ez12a
This is the one i picked up:
https://www.ebay.com/itm/Original-Mi...AAAOSwopRYZIra
The more expensive dongles have more features it seems. The seller provided the software via download and in CD form with the cable.
Old Jan 22, 2018 | 04:43 PM
nobelnabil's Avatar
nobelnabil
yours is the newest version and it works with 64bit OS, the cheaper ones only work with xp/windows 7 32bit version only (firmware is 1.0.4 i think)
Old Jan 23, 2018 | 10:32 AM
AgedGS's Avatar
AgedGS
Good info. thanks guys.
Old Jan 23, 2018 | 03:34 PM
MX73's Avatar
MX73
Mine just came in. Firmware 1.4.1 running on win10 64bit.
This is the one I ordered, http://www.obdii365.com/wholesale/mi...oyota-tis.html. I only needed to turn off the DRLs.
Wowzer. I found some code stored for the ABS, low or high power supply voltage and a malfunctioning humidity sensor circuit
Edit - I've played with the cable a bit more. Looks like I have the ability to register new TPMS! I'll have to wait until my new sensors come in.
Old Jan 23, 2018 | 05:56 PM
RA051724's Avatar
RA051724
While I was looking in eBay, I got the feeling this is actually pirated software, not the real Techstream, which would likely cost substantially more. Am I on the right track?
Old Jan 23, 2018 | 06:59 PM
ez12a's Avatar
ez12a
It is a pirated copy of Techstream.
Awesome! It's pretty neat what you can find. It showed me my transmission codes before they popped up as actual MILs. Included freeze frame data too.
Old Jan 23, 2018 | 07:09 PM
MX73's Avatar
MX73
It actually made me wonder why it didn't throw a CEL or a BRAKE warning light.
Old Jan 23, 2018 | 08:03 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Techstream software download
https://drive.google.com/drive/u/0/m...3M?usp=sharing
See post 5 to build an easy VSC light reset tool.
Old Jan 23, 2018 | 08:09 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
TPMS sensor testing and programming
https://www.clublexus.com/forums/sc4...02-2006-a.html
