2006 GS430 Magic Drift ING Front Lip Install Questions??
Old Nov 5, 2017 | 08:50 PM
rxmpvibes's Avatar
rxmpvibes
Default 2006 GS430 Magic Drift ING Front Lip Install Questions??
Hello everybody, has anyone installed the Magic Drift ING Front lip spoiler on their GS? If so, I need some advice on how to properly install this lip. I'm having some fitment issues, it seems like the fitment is off and the lip is not lining up with the front bumper. Sections of the lip is going against the foglights (do i need to remove both foglights?). The middle section of the lip is going against the lower black grill. What modifications need to be done to make this lip fit. Thanks!
Old Nov 6, 2017 | 08:51 AM
MX73's Avatar
MX73
What year is your GS? Lexus redesign the front bumpers for the 08-11 models.
Old Nov 6, 2017 | 01:02 PM
ibidu1's Avatar
ibidu1
Take off the fog lamps if they are easy and the grille and test fit. How does the lip attach on, with double sided 3m tape?
Most likely you can do some trimming or even sand down the edges that you need to shrink up.
Old Nov 6, 2017 | 08:02 PM
XxGoKoUxX's Avatar
XxGoKoUxX
What ibidu said, you'll need to either trim it or have the paint shop trim it.
Old Nov 11, 2017 | 05:36 AM
rxmpvibes's Avatar
rxmpvibes
Ok, thanks for the responses everybody. My GS is a 2006. So, it turned out they sent me the wrong front lip. They sent me a front lip for an IS not a GS . I'm waiting on the shipment to arrive, I will keep you all posted.
Old Nov 26, 2017 | 06:25 AM
rxmpvibes's Avatar
rxmpvibes
I finally got the the Magic Drift ING front lip installed. It did need a little modification to make it fit. A heat gun and dremel were my best friend in getting the front lip to fit correctly. I did all the prep work and painted it myself in my backyard. Overall, I'm happy with the results. Here are some pics that I took while doing this project:
Used heat gun to adjust lip.
Had to use a dremel to even out this area.
I removed this part from under the car because it was in the way.
Test Fit Complete
Wet sand all areas really well with 220-320 Grit. *Important* *Preparation is key!!!
After Wet sanding and when dried this is how it should look
After applying Primer
Wet sand bumper with 400-600 Grit sandpaper so basecoat paint can stick. *Important* *Preparation is key!!!
Factory Black Toyota/Lexus Paint from SEM
4-5 Coats of base coat. Base coat is complete.
Had some PPG Shopline Euro clear coat left over from when I painted another one of my cars. The clear coat kit alone costs $400. This is some high quality clear coat!
I used my spray gun to shoot the clear coat
The final product! No wet sanding or buffing! Look at that finish! That clear coat laid flat! You barely see any orange peel!
Installed on the car, very satisfied with the overall look and finish!
Old Nov 27, 2017 | 04:00 PM
Stormforge's Avatar
Stormforge
executive matchup
Good job on a DIY project! Next project, side skirts and rear lip.
Old Nov 28, 2017 | 05:47 PM
rxmpvibes's Avatar
rxmpvibes
Unhappy
Thanks I appreciate it! I was thinking about doing the side skirts and rear lip but, I can't find who sells the ING rear lip. I did find the side skirts on eBay here:https://www.ebay.com/itm/Ing-Side-Sk...xZ8Z~X&vxp=mtr
Do you know where I else I might be able to find them?
Old Nov 29, 2017 | 10:42 AM
Stormforge's Avatar
Stormforge
executive matchup
I would have to check, as I don't know if the companies I used to deal with are around anymore. But for sure keep looking, I'm sure you'll find it. Good luck!
k20trick
IS F (2008-2014)
16
May 21, 2018 04:29 PM
Chanhing23
Jul 14, 2017 10:44 PM
PilgrimIS
Nov 2, 2014 12:59 PM
TexasGS
Oct 22, 2005 08:51 AM
Dpark
IS - 1st Gen (2001-2005)
Jun 20, 2001 02:50 PM
