P0057 O2 Sensor - Check Engine/VSC
So my 2008 GS350 AWD has had the Check Engine/VSC light on for a while. I was near a dealer the other day and stopped and asked them to let me know the issue. They said $180 to run diagnostics. I said "huh!" He said we can tell you the code for free though. I said ok. So they plugged it in and it came back with the P0057 code, which from looking around is the O2 sensor (Bank 2 Sensor 2). I think, if I'm right, the part number from Denso is 234-4519 (Downstream Left) and is about $65. I saw some good diagrams onlin. Just wondering if anyone has changed one and how hard is it? Any suggestions?
If the sensor is actually bad, I would buy oem or denso brand
If you replace the downstream O2 sensor yourself, do yourself a favor and purchase this specific tool designed for Toyota/Lexus. Fits perfect in the tight spacing. This tool, with a little PT Blaster the night before, will make it a breeze. Also, be careful removing the carpet and plastic panels...easy to break clips.
Schley Products SL66750B TOYOTA OXYGEN SENSOR SOCKET | Tool Discounter
Also agree with ibidu1, buy only OEM or Denso brand. RockAuto has a very good price on the Denso.
Good luck.
Good luck.
whoyouknow
12-13-18 12:26 PM
