4GS TPMS on my 3GS with aftermarket wheels
I've search and haven't been able to get a for sure answer. Does anyone know if the 4GS TPMS sensor will work on my 3GS?
I had a local tire shop replace my aftermarket wheels. Long story short, those idiots broke my sensor while doing so and replaced it with a regular valve stem. I went eBay on purchase a rebuilt sensor but accidentally bought a 4GS one. It looks almost identical but I am not sure if it'll be able to program with my car. Since they are going on my weds, I'm not worried about fitment. If it works I rather just install it then having to do the whole exchange process.
Thank you!
Thank you!
Sensors vary based on the year of the car. i.e. a 07 3gs may be different from an 10 because of difference in tech and software used as a later model may have newer tech/software. Even if the sensor you bought is the correct year for your 3gs, it still needs to be programmed for the vehicle via obd and a tpms tool such as a bartech. Just take it to a shop that is reputable and they can usually scan the sensor letting you know if it will work or not.
Your story should've end up with them fixing/buying you a new sensor.
GQis350
08-26-12 08:35 PM
