Murky HIDs
Old Mar 8, 2017 | 09:11 PM
vszrm's Avatar
vszrm
Unhappy Murky HIDs
Hey guys,
I just installed a set of XenonDepot 6500k HIDs, and I'm really fond of the new color. However, as I'm starting to pay closer attention to the headlights, I'm noticing that my headlight seems murky, where there's almost a holographic reflection on the lens itself. I don't remember how the headlights looked before I installed them, and I can't find any threads that pertain to my issue at-hand. From what I've heard, changing the HIDs under the appropriate wattage shouldn't cause any melting or harm in general, but the lights are always warm to the touch after I drive, which I like to believe is normal, but am unsure of if it really is. Again, I don't remember how they were before I installed them.
There used to be condensation in the headlight, so the only solution I have is that it's the leftover residue that's causing it. The output is perfectly fine, and it's unnoticeable in daylight. Has anyone experienced something similar to this or does anyone have a solution? Any help would be greatly appreciated!
Thanks,
Richard
Old Mar 8, 2017 | 10:21 PM
tcr101's Avatar
tcr101
If you had condensation within the housing, moisture/dirt probably got inside the housing. The main way I know to fix this is bake open the light and polish the inside and outside of the clear outer lense.
Old Mar 9, 2017 | 07:48 AM
pbxcomm's Avatar
pbxcomm
Has anyone visited this site or have had purchasing experience with this seller?:
http://www.ebay.com/itm/D4S-x1-NEW-OEM-90981-20024-20013-HID-XENON-Replacement-Headlight-Bulb-/182404325430?hash=item2a78252036:g:J0kAAOSwt5hYZfSJ&vxp=mtr
Old Mar 9, 2017 | 11:25 AM
TRD_Power's Avatar
TRD_Power
Are you positive it's all on the inside of the housing? Maybe try a quick cut and buff on the outside first, then see if it's still there. That's exactly how mine look after they get a little dirty, but once I wash them, they're crystal clear again. Besides that, your best bet is breaking them open and polishing them up. Also, you mentioned that there used to be condensation inside - did you break them open to clean them and re-seal? If so, did you use any sort of wax on the inside? That can cloud up over time as it degrades.
Old Mar 10, 2017 | 02:57 PM
tcr101's Avatar
tcr101
Originally Posted by pbxcomm
Never used them before, but the markings on the bulb look correct. For a bit more (~$100 and change) you could get some Phillips ultinons
J$mooth23
May 6, 2018 08:32 PM
k20trick
IS F (2008-2014)
Dec 7, 2015 10:08 AM
TT4U2NV
Aug 5, 2012 07:32 PM
Stevoe88
Apr 26, 2011 02:11 PM
scottys209
Apr 11, 2011 10:13 PM
