B1000 code
Old Jan 3, 2017 | 08:08 PM
oraneivey's Avatar
oraneivey
Default B1000 code
im getting a B1000 code. I've changed 2 airbag modules so far and code cones right back and still can't get airbag light to clear. Is there a step that I'm missing? Is there something else I need to do?
Old Jan 4, 2017 | 12:15 AM
ibidu1's Avatar
ibidu1
Have you put it on a scanner to scan the full airbag setup? If not any decent mechanics shop scanner can do the job. Shouldnt cost much to ask a shop or you can buy a obd2 wire and download techstream and pull the codes yourself.
Was the car in an accident and you replaced all the airbags? If so did you replace seatbelts? Also sometimes if the drivers airbag goes out, the steering wheel clock spring behind gets faulty.
Old Jan 11, 2017 | 04:10 PM
oraneivey's Avatar
oraneivey
All the above has been done. I'm not getting any other codes for SRS but b1000. Does any one have any similar issues like this. What else can I check or do to get this code out. Just got a 3rd airbag module and same code.
Old Jan 12, 2017 | 12:02 PM
Gs3500's Avatar
Gs3500
Did you figure out what circuit B1000 refers to? How do you know it is the module to begin with? Try to identify the root cause of the problem before you swap out more parts.
es330on22s
Sep 22, 2016 03:13 PM
Egone
May 11, 2011 10:24 AM
mobilyte
Jun 20, 2007 08:51 PM
Chungstyle
Feb 17, 2006 12:25 PM
