Brakes are weak
Old Dec 21, 2016 | 07:53 PM
Lukas99GS's Avatar
Lukas99GS
Default Brakes are weak
My 08 GS460 has what feels to me like very weak brakes, the pedal isn't very responsive, driving newer lexus' I've noticed they all have much stronger brakes that react instantly when barely even touching the brake pedal, even my girlfriends 2016 Corolla brakes are much stronger and more responsive than mine. I've brought it to Lexus and they say everything is fine. The car still stops ok and its not to a point where I feel like I'll hit anyone but I'd imagine they were much better when the car was new, pads and rotors are still good and dealer didn't notice anything with calipers, is this just normal on 3GS? Or has anyone else felt this? I saw there was a thread a while back about the LS and GS460 brake actuators.
Old Dec 21, 2016 | 08:35 PM
ServerTech's Avatar
ServerTech
Have you ever changed/flushed the brake fluid? Suppose to be done every 3 years as brake fluid absorbs water from the atmosphere.
Old Dec 21, 2016 | 09:53 PM
Fausty's Avatar
Fausty
When I got my car the actuator was failing and I felt similar to what your describing. I specially felt it when I would press the brake, the pump would start buzzing and my braking felt much weaker than when it wasn't buzzing. After I had it changed braking felt much stronger. It couldn all be subjective but that was my experience.
Old Dec 22, 2016 | 01:25 AM
Lukas99GS's Avatar
Lukas99GS
Brake fluid was flushed by Lexus less than a year ago.
Old Dec 22, 2016 | 01:30 AM
Lukas99GS's Avatar
Lukas99GS
I saw in a thread that Lexus was replacing the actuator for people but I'm not sure if they're still doing that, my car has no warning lights, and doesn't really make any kind of noise while braking. I do hear a buzzing when I turn my car off for a couple seconds, but I'm not sure if that's the brake actuator or something else.
Sucks because I have a warranty on the car that would cover something like that anyway but Lexus claims nothing is wrong.
Old Dec 22, 2016 | 03:14 PM
MX73's Avatar
MX73
Any leaks from the braking system? Maybe air was introduce over time. A mechanic that I know a few years back adjust the push rod behind the brake pedal on my '03 Corolla to "increase" the "firmness" when you push down on the brake pedals. Not sure if you could do this on the GS.
potatomon
Apr 15, 2019 04:41 PM
semar
Aug 23, 2015 07:46 PM
RXGS
Maintenance
Sep 19, 2008 02:15 PM
ravengotu
RX - 1st Gen (1999-2003)
Aug 26, 2005 02:47 PM
Lexs400
Jul 8, 2005 02:29 PM
