Work wheel set up
I just bought a 2011 gs350 and I own work schwert sc2s...the fronts are 20x9.5 with a +25 offset and an O disk...im wondering if there's anyway i can install them. Thanks for the help...
You'll be super aggressive as the O disk will need at least a 20-25mm to clear the front brake calipers.
So technically it'll be 20x9.5 +5 offset (or 0 offset), it'll fit, but it'll be super super aggressive regardless whatever you're lowered on even if you're stock height, it'll stick out A LOT.
I tried ordering O disk all around, even an A disk will need a spacer.
