Fog light connector problem.
Old Oct 2, 2013 | 12:49 PM
LADavidGS's Avatar
LADavidGS
Default Fog light connector problem.
I just discover this today. Any recommendations?
Old Oct 2, 2013 | 12:54 PM
IXI187IXI's Avatar
IXI187IXI
what watt is the bulb? i assume its an aftermarket bulb correct?
Old Oct 2, 2013 | 12:59 PM
LADavidGS's Avatar
LADavidGS
stock bulb 55w. I wanted to install the nokya yellow 9006 55w bulb but discovered this problem.
Old Oct 2, 2013 | 01:04 PM
IXI187IXI's Avatar
IXI187IXI
hmmm interesting
check this thread out where a member did almost the same thing but he was running higher wattage bulbs. from the last post in that thread, sounds like you might be able to just swap the connectors
Old Oct 2, 2013 | 01:05 PM
LADavidGS's Avatar
LADavidGS
how hard is it to replace the connectors? And where can i buy them for cheap?
Old Oct 2, 2013 | 01:10 PM
XxGoKoUxX's Avatar
XxGoKoUxX
Here you go brother, you can even upgrade to the nokya if you'd like too... Since they're built for higher heat.
http://www.ebay.com/itm/Heavy-Duty-Ceramic-9006-9012-HB4-Wiring-Harness-Sockets-Pre-Wired-/151007949315?pt=Motors_Car_Truck_Parts_Accessories&hash=item2328c67203&vxp=mtr
You'll need to cut your old harness, and either solder (if you have soldering skills) or you clamp them with these:
http://www.ebay.com/sch/i.html?_odkw...ector&_sacat=0
You'll need a butt connector crimp for them....
On a side note, I forgot they're called butt connectors, so I ebayed butt plug.... will not be doing that again.
Old Oct 2, 2013 | 01:15 PM
IXI187IXI's Avatar
IXI187IXI
not sure, i never replace one nor do i know if you can. i was just going off that thread. i remember that thread because he used a higher wattage bulb which is what caused his issue. i know you can buy the full harness but i assume thats pretty expensive.
LADavidGS's Avatar
LADavidGS
Thank you XxGoKoUxX for your input. Another question, do you recommended oem 9006 connectors or autozone one?
Old Oct 5, 2013 | 02:13 PM
LADavidGS's Avatar
LADavidGS
Can I use splice connects to connect the wires?
Old Oct 5, 2013 | 06:59 PM
XxGoKoUxX's Avatar
XxGoKoUxX
I recommend the online ones, the Autozone/advanced auto part connectors are for OEM bulbs only, and they will DEFINITELY burn out again later on down the line.
You can, but you shouldn't. Cut, butt connectors, heatshrink. Call it a day .
Actually, I would lean more towards, you can't, because that's a lot of resisitance for you to be pulling off of for each connector, you might end up heating/burning the splice connectors.
GL!
miles56
Apr 14, 2013 12:13 PM
chuckli
Jul 20, 2010 01:54 PM
Alexus-Kia
Jun 8, 2005 10:51 PM
Nomis
Lighting
Sep 16, 2004 08:54 PM
goral19
Oct 15, 2001 11:19 PM
