Recalls? need info
Old May 20, 2013 | 08:32 AM
nowayjames's Avatar
nowayjames
Default Recalls? need info
So i have a GS350 2010, and im wondering how do i find out which recalls/FSB like https://www.clublexus.com/forums/all...engineid=3931/ have been done?
I registered my VIN on the Lexus drivers, but i did not see anything much done about the things listed under there... is there a way i can find out?
1.My brakes have been squeaking/screeching when i apply them lightly on stops, its annoying ...
2.On start up i hear metal grinding noise... rarely on some start ups recently alil more
3.Sometimes my mirrors dont go back in position when i go from reverse to drive/ drive to reverse
4.Steering wheel steers itself/pulls when trying to drive straight
5.GPS Nav says i am at some location when im somewhere else near..
Afew problems i must say.. would it cost me out of pocket if i were to ask them to check for all those problems? I bought this vehicle from a dealership not even 2 months ago and i never dealt with dealerships before..
Thanks for taking your time for the long read, im scratching my head and stressing out about this, i didn't think a lexus 2010 would have this much problems. Expected abit more
Old May 20, 2013 | 08:39 AM
98GS430's Avatar
98GS430
The noise on startup is caused by faulty cam actuators. I just had this service done. Theres a TSB and unless you are over 70k miles the warranty covers it. I believe there is also a TSB for the brake noise, if you are under 50k miles the warranty covers that as well.
Old May 20, 2013 | 09:21 AM
nowayjames's Avatar
nowayjames
What do i tell them when i roll up there? the car only has 36k atm
Old May 20, 2013 | 12:24 PM
Brabusx2's Avatar
Brabusx2
ur car is 2010 and under 50k miles, u shouldn't have any problem pulling up and tell them that, worse case they will test drive your car and BS u everything is fine, video record your car next time when braking show them the noises you hearing, and video record your GPS as well, as for wheel pull, is the road perfectly flat or badly pave? because our car has wide tire and it tend to go with all the detail on the roads so it pull everywhere which is normal.
Ravishah89
Mar 18, 2015 09:14 AM
shonda2620
Jul 31, 2014 01:26 PM
EricB
GX - 1st Gen (2003-2009)
Mar 12, 2013 09:14 AM
Ice350
Nov 30, 2008 11:31 AM
