Tint n Wheels
Old May 4, 2013 | 01:15 PM
sobe69's Avatar
sobe69
Default Tint n Wheels
new wheels and tint, going on ez streets next week
Old May 4, 2013 | 01:38 PM
ibidu1's Avatar
ibidu1
Looks good!
But tires look small on it. What size are you running? Also why didnt you go staggered, it would have filled the rear nicely.
Old May 4, 2013 | 01:47 PM
sobe69's Avatar
sobe69
245/30/20....i was going to go staggered, but was told by every tire shop not to for the AWD...
Old May 4, 2013 | 02:29 PM
benztolex's Avatar
benztolex
Nice! Are those TSW?
Old May 4, 2013 | 03:18 PM
Lex Luga's Avatar
Lex Luga
Do research before listening to guys at the shops. You can do awd and staggered set up. My summer and winter sets of wheels are both staggered set ups. You just need the same rolling diameter (i think that's the correct term) in the front n back wheels. Basically it's all about the tire sizes I'm no expert but I do llisten to the ones in this forum.
Old May 4, 2013 | 05:45 PM
ibidu1's Avatar
ibidu1
Im AWD staggered and no issues, ya def take advice from this board instead of outside.
You do know when you lower an AWD it will vibrate and whobble
Old May 4, 2013 | 09:17 PM
sobe69's Avatar
sobe69
Ive read that, but a few with the EZ Streets have reported no issues, just hoping its not too bad!!
Old May 5, 2013 | 03:11 AM
ibidu1's Avatar
ibidu1
The brand of springs or coilovers does not matter to the AWD. What matters is the amount of drop, because the cv axles were design too short for our cars. The slightest drop allows the axles to fit loosse, so you get vibes and whobbles. If you add length (spacer 9-10mm) to the cv axle this should cure the vibrating and whobbles.
Also what I believe has some effect is how the wheel alignment is adjusted. The more negative camber the more it helps stopping vibrations. This is why I believe, certain GS AWD's vibrate with Fsport springs and others don't.
With the EZ streets you might be able to get away with 1" drop, play with the adjustments till you get it right.
Old May 5, 2013 | 04:33 AM
sobe69's Avatar
sobe69
I appreciate the help, this forum is great!!
Where could I get these spacers?
Old May 5, 2013 | 09:15 AM
Diesel350's Avatar
Diesel350
Those look like the Ace Alloys. What offsets did you get them in?
Old May 5, 2013 | 09:47 AM
ibidu1's Avatar
ibidu1
Any metal fabrication shop should be able to make the spacers for you.
https://www.clublexus.com/forums/sus...rs-needed.html
Old May 5, 2013 | 11:41 AM
sobe69's Avatar
sobe69
20 x 8.5 +38
Old May 5, 2013 | 03:35 PM
bigblack06's Avatar
bigblack06
Wheels look fine you need to drop that bad girl and you will be good. They do look like TSW wheels.
Old May 5, 2013 | 05:50 PM
MX5's Avatar
MX5
Looks great. I plan to go all the same on my AWD, too, so I can rotate and get some decent life out of the tires.
Old May 5, 2013 | 05:59 PM
sobe69's Avatar
sobe69
Actually from a company out of Montreal, reasonable and a nice wheel, thank you...going for the drop next week....blacked out the roof today though and love the look.
