Valve spring replacement issues
Lexus dealer informed me about a gas consumption increase, which i am ok with but i am definitely not ok with a oil consumption increase with no explaination as to why the increase or where the oil is being consumed.
I didn't have any issues what so ever with this car before the valve spring change and totally regret doing the recall work. There is only 98,000 miles on this car which Lexus promotes as a low mileage engine and yet i can not make an oil change without adding 2 liters of oil. To make matters worse i just dished out 800 dollars for the Lexus dealer to test the valve seals and check the valve spring replacement work.....and no anwers as to where the oil is going. No oil leaks, spark plugs look great ( as per Lexus ) and no signs of burning oil........so begs the question, where the hell is the oil going??
Does anyone have any ideas and / or have the same oil consumption issue?
I totally love this car and was an exceptional car up until the valve spring replacement. Any replies would be appreciated.
Thank-you,
Thank-you,
