3gs Water Pump Failure Thread
Old Jan 26, 2013 | 05:04 PM
  #31
chuckGS350's Avatar
chuckGS350
Originally Posted by rld14
I checked mine less than 20 miles before my car blew up. It was full.
That's odd.
Maybe I should open the radiator cap & check the coolant level.
Old Jan 26, 2013 | 05:51 PM
  #32
ibidu1's Avatar
ibidu1
The pumps are $110.00 no reason in waiting for it to go out. If you have over 60-70k its probably best to replace it.
Old Jan 26, 2013 | 06:04 PM
  #33
bigblack06's Avatar
bigblack06
Maybe if Lexus sees this they will decide to put a low coolant light in the next GS cause I don't think the new GS has it still. Which is pretty sad, best bet get it checked if your around 65K and up as preventative.
Old Jan 26, 2013 | 06:29 PM
  #34
tcr101's Avatar
tcr101
When they say "continuously leaking", i am assuming if you park a car overnight you will have a puddle underneath?
Old Jan 26, 2013 | 06:41 PM
  #35
ibidu1's Avatar
ibidu1
No pink seeping onto the pulley
Old Jan 26, 2013 | 07:21 PM
  #36
chuckGS350's Avatar
chuckGS350
If you see that, you better replace the water pump ASAP.
Continuously leaking means the leak is current.
From L-SB-0091-11:
File Type: pdf
Old Jan 26, 2013 | 07:27 PM
  #37
aLexGS350's Avatar
aLexGS350
Took mine for maintenance and the dealer told me my water pump was leaking also. I'm at 66k miles now. He told me to call a number to see if I still have warranty to get it replaced.
Old Jan 26, 2013 | 07:34 PM
  #38
chuckGS350's Avatar
chuckGS350
I still have 11 months/20K miles left on the EW. So I will keep my eyes on it.
I checked my service record. I had a coolant flush performed at 50K miles.
That may have helped preventing the leak.
Knock on woods.
Old Jan 26, 2013 | 07:36 PM
  #39
chuckGS350's Avatar
chuckGS350
Is the water pump covered under power train warranty?
If yes, it should be covered until 75K miles. Dealer should know that. Why do have to call?
Old Jan 26, 2013 | 08:32 PM
  #40
passnu2's Avatar
passnu2
Powertrain Warranty
The Powertrain Warranty is for 72 months or 70,000 miles, whichever occurs first. Except for the situations listed on the Basic Warranty page, this warranty covers repairs needed to fix defects in materials or workmanship of any component listed below:
Engine
Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets
Transmission and Transaxle
Case and all internal parts, torque converter, clutch cover, mounts, engine control computer, seals and gaskets
See your Lexus dealer for complete details on the Lexus Powertrain Warranty.
Old Jan 26, 2013 | 08:38 PM
  #41
passnu2's Avatar
passnu2
Only those with the GS450h
Drivetrain 8 year / 100,000 miles
Old Jan 27, 2013 | 12:49 PM
  #42
rld14's Avatar
rld14
Water pump is covered under power train warranty. Damage caused by water pump failure isn't regardless if you had the ability or knowledge to prevent it.
The 4th gen GS doesn't have a low coolant warning? That's not silly, that's idiotic. IMO anyone who has one of these cars and is past 60k should change their water pump, if you don't you could end up totaling your car.
Old Jan 27, 2013 | 01:42 PM
  #43
KJSmitty's Avatar
KJSmitty
I'm thinking the 6 year and/or 70k mile point - whichever comes first would be a good time. If she goes prior to that its Lexus' dime.
Old Jan 27, 2013 | 02:20 PM
  #44
chuckGS350's Avatar
chuckGS350
I read the EW agreement. The engine broke down because of the water pump failure should be covered because the water pump is a covered component. Unless Lexus believes engine failure due to overheating caused by "lack of or improper maintenance", "not maintaining proper levels of coolants, oils, and/or lubricants".
Lexus has my service records. If they deny my claims, I will fight them all the way.
Just like the timing belt. If the timing belt breaks and causes the valves bent, they should be covered.
Old Jan 27, 2013 | 06:33 PM
  #45
rld14's Avatar
rld14
It should have been IMO. Had I driven the car when I knew it was overheating it would have been my fault. Had the temp gauge moved anything past normal I should have known and it would have been my fault.
The car actually acted like it lost a timing chain, all of a sudden there was a rattle and then BOOM! No power and the car stalled, the temp gauge was RIGHT IN THE MIDDLE while this happened.
I'm convinced that I had a catastrophic failure of the water pump seal or bearing and that the car was blowing out coolant underneath it at a very rapid rate.
Here's what the end result was:
They saved $3,750 or so in labor.
I didn't buy a 2013 GS350 and ordered a Jaguar.
My brother didn't get another RX and got a Grand Cherokee.
My then girlfriend didn't replace her GX and got a Q7 TDI.
None of us will likely ever buy a Toyota or Lexus product again. Ever. I cant speak with certainty about anyone else but I will NEVER buy another Lexus, and on top of that anyone who asks gets the story. My girlfriend in particular was outraged, probably angrier than I was. She's also a television reporter and I wanted to put this behind me but she wanted to do a story on it. In hindsight I should have, but oh well.
Spoke to a friend of mine who is a bit of a big shot with Audi, had this happened to an Audi there would have been no questions asked, I'd have had the car fixed for no charge and probably within a week, not 7.
As far as lack of maintaining the car goes, that's a load of crap. My car gets oil changes with synthetic every 3k and I use Toyota/Lexus filters. I change my coolant annually, I changed my plugs at 50k, I change air filters every 10-15k, and every fluid in the drivetrain has already been changed way ahead of schedule.
If my whining and carrying on saves someone else from being victimized by a combination of lousy quality, poor design and lack of accountability then I'm happy.
Bill
