Old 01-09-15, 03:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
***DIY: Rear Diff Oil Change (w/ pics)***
Old 11-15-13, 11:00 PM
alSpeed2k
alSpeed2k's Avatar
^I agree, it's perfectly okay to jack a car up from it's diff.
Old 11-26-13, 06:55 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,854 Likes on 2,337 Posts
Not always. I just did the brakes on a Cayman, and Porsche says very specifically NOT to use the differential housing. Most Lexus/Toyota vehicles are good with the differential and crossmember. The LFA cannot be lifted this way - there are three pages of instructions for safely lifting the LFA.
Here's the GS information:
Old 02-07-15, 09:17 PM
gr8fulRed
gr8fulRed's Avatar
so...I completed this rear diff drain/refill today and things went off without a hitch. I do have a question though...
i dropped the old fluid into a catch pan and then poured it from the pan into a pre-marked clear milk jug that had already been marked off in quarts (1, 2, 3, etc)...in order to measure what came out. The best I can tell...I took out approximately 1.59 qts (51 oz). From measuring what new fluid was left over, it seems i've added 1.68 qts (54 oz). Now, with a little very minor spillage (going in) and a very little left in the catch pan, and then into the measuring container which throws off the ACTUAL dropped/added fluid...I should still be very close. My question....is it possible to over fill the diff?? The drain plug hole is on the upper SIDE of the diff (not the very top)...so I assumed once fluid starting dripping out...I was good to go. My car was level..or at least VERY close (maybe 1/2 off from front to back). How could I have put IN more than I took out?? I don't want issues.
Old 02-08-15, 05:07 AM
burny
burny's Avatar
as long as car was level you are good. Fill until starts coming out the fill hole and button it back up
Old 02-08-15, 06:32 AM
gr8fulRed
gr8fulRed's Avatar
well, this is what I did...so I guess I'm good to go. Thanks for your timely responses. Very much appreciated.
Old 03-24-15, 08:17 AM
waynesreef
waynesreef's Avatar
Thanks for the write up. I am going to change mine when the weather warms up a bit. By the way did you change the oil for the front differential as well? The front ones is hard to get to according to the service manual. I might just let the dealer do it since they are only asking $89 for it.
Old 03-25-15, 03:32 PM
jrodlsx
jrodlsx's Avatar
Good write up. Will be doing this soon along with trans fluid service.
Old 01-29-16, 07:32 AM
Rocknrose
Rocknrose's Avatar
I will tackle this next. first I'm going to do the transmission fluid.
Old 02-01-16, 06:24 PM
Brabusx2
Brabusx2's Avatar
is it same for GS450h anyone know? planning to do this as wel..
my friend told me he sould a "hand soap pump", what other pump you guys recommend
Old 05-27-17, 11:19 AM
Rocknrose
Rocknrose's Avatar
Smile Rear End differential change
I bought the gear oil and jack stands and due for lack of time I took it to my regular shop and gave him the gear oil and 3 quarts for the transmission for my 2007 GS 350.
Surprisingly he only charged me $50. Runs strong despite the almost 200,000 miles.
Old 05-27-17, 11:44 PM
Brabusx2
Brabusx2's Avatar
quick question, i did the job myself a year ago and for some reason my car took in 2 whole bottle of the diff fluid and nothing comes out, is it safe? i felt like the tank can take in more,
Old 05-28-17, 04:11 PM
Sodium
Sodium's Avatar
Did you have the car level when filling the diff? The diff holds a bit less than 1.5 quarts, so if they were 1 quart/1 liter bottles the fluid should've started trickling out of the fill hole about halfway through the second bottle
EDIT: Just noticed you have a 450h. The manual I have is for the 350/460 and doesn't mention 450h differential capacity, so you may want to check your manual. I can't think of a reason why the 450h diff would have a different fluid capacity, especially since the 350 and 460 use the same diff, but best to check and be sure
my808lexus
08-18-14 08:51 AM
tangomike7
RX - 1st Gen (1999-2003)
11-13-13 05:17 PM
pwrusr
02-24-12 08:47 PM
96732IS350
01-18-12 11:24 AM
Quick Reply: ***DIY: Rear Diff Oil Change (w/ pics)***
