Jack point location
Old Aug 6, 2012 | 09:37 AM
tekkie's Avatar
tekkie
Default Jack point location
Hi,
Does anyone have a good picture of the exact jack point location (front and rear)? I can not make out the location from the manual. Thanks very much in advance.
Old Aug 6, 2012 | 10:50 AM
burny's Avatar
burny
rear is under the pumpkin. front is where the cross members cross
Old Aug 6, 2012 | 05:11 PM
tekkie's Avatar
tekkie
Thanks for the reply. Would you happen to have pictures showing where these locations are? I just don't want to do something I regret by using the wrong locations. Thanks.
Old Aug 6, 2012 | 08:47 PM
alchemist's Avatar
alchemist
Front is harder to find than rear, you need to get under there. Take your time. If you want to jack from the side look at my "diy wheel stud" thread i have pics
Old Aug 7, 2012 | 06:29 PM
tekkie's Avatar
tekkie
Thanks...your "dyi wheel stud" picture helps. I will try on the weekend.
Old Sep 7, 2015 | 09:25 AM
Gs3500's Avatar
Gs3500
So the front jack point is Between the oil pan and the front bumper right? And for rear, it's just on the differential?
Old Sep 7, 2015 | 03:41 PM
sprtn131's Avatar
sprtn131
Nooo! Sorry but do not listen to burny. The jack point are on the pinch weld. If those are no good lift by the frame. Not a good idea to lift the rear diff. If it is a truck with a solid rear axle, ok but not good for gs
Old Sep 7, 2015 | 04:07 PM
sprtn131's Avatar
sprtn131
The pinch weld is located just behind the plastic side trim, most of it is covered by plastic, there are gaps in the front and rear. That's where you should jack.
However if yours look like mine...
Front.
And
Rear.
You'll want to lift by the frame
Old Sep 8, 2015 | 12:13 AM
xbladex00's Avatar
xbladex00
Front.
And
Rear.
This is exactly how my jack points look like without the rust... I used my 2 1/4 ton duralast jack and This is what happens... I put in between the grooves and most of the time when jacking it up i hear clinking or metal bending sound.... I definitely don't recommend my jack or are the GS jacking points really ****ty?
Old Sep 9, 2015 | 03:49 AM
avs20's Avatar
avs20
I jack mine up by the pinch welds, but I use a hockey puck with a channel cut out of the middle. Works great and no bent metal
Old Sep 9, 2015 | 06:54 AM
sprtn131's Avatar
sprtn131
That's genius
Old Sep 9, 2015 | 07:46 AM
uberEJ's Avatar
uberEJ
i use a 2x4 with the channel cut out. well its not a complete 2x4 more like a 2x3
Old Sep 9, 2015 | 02:07 PM
sha4000's Avatar
sha4000
Pics of the hockey puck and 2x4 plz.
Old Sep 9, 2015 | 10:00 PM
BinaryJay's Avatar
BinaryJay
Or just use the scissor jack that comes with the car which I find completely and totally adequate to the task and doesn't damage the jack points at all. It's not like I lift the car every day so I don't sweat over the extra minute having to spin the gear.
Old Sep 10, 2015 | 12:03 AM
avs20's Avatar
avs20
Just search google for 'hockey puck jack pad'. Some companies sell them pre made...but I just went to ****'s Sporting Goods and bought a puck and took my sawzall to it.
