Battery Drain Causes VSC/Engine Light Activation
Old May 13, 2012 | 05:45 PM
Red112fl's Avatar
Red112fl
Default Battery Drain Causes VSC/Engine Light Activation
After stupidlly allowing my battery to run down today, the car's "VSC" and "Check Engine" lights came on. after i jump=started ed the battery from another car. Thanks to this great forum. i was able to fix the issue -- a member previously suggested that disconnecting the negative battery terminal cable to clear the false code. Problem solved! There is so much great information here!
ls400geek
May 21, 2016 05:53 PM
kim0217
Oct 30, 2015 04:02 AM
boss22
May 2, 2012 04:58 PM
tukteuktik
Nov 5, 2008 08:22 PM
susanjane
RX - 1st Gen (1999-2003)
Aug 10, 2006 06:34 AM
