question about 2006 gs300 transmission
Old Feb 28, 2012 | 08:51 PM
LADavidGS's Avatar
LADavidGS
Default question about 2006 gs300 transmission
new owner and wondering if anyone can shed some light regards to 06 gs300 auto transmission. From a full stop, when accelerating i have having two issues:
1. 2nd gear seems very shortest gear engaged vs. other gears.
2. the transmission seems lethargic..
Old Feb 29, 2012 | 09:22 AM
Boron's Avatar
Boron
Have you driven the car in sport mode?
Have you used the transmission in semi-manual mode?
If so, did the former still make it seem lethargic?
Did the latter reinforce the short 2nd gear ratio feeling?
If not, then could just be the algorithm used to keep the revs down while making progress, to increase fuel economy.
What's the mileage?
Did you buy privately or from a dealer?
If a dealer, do they have another car on the lot that will let you gauge whether it's just unfamiliarity with the car, or possibly a problem with yours?
Old Feb 29, 2012 | 10:25 AM
LADavidGS's Avatar
LADavidGS
What's the mileage?
I have driven the car in sport mode and its response is quicker.
I have driven the car in semi-manual mode and everything seems normal.
When driving in normal mode, only the 2nd gear seems lethargic.
The shift from 2nd to 3rd gear is very prompt, barely reaching 1500 rpm.
current miles is 39k
i purchased the car from a private party w/ clean title.
Old Feb 29, 2012 | 11:09 AM
EnK's Avatar
EnK
Sounds normal to me, I think Lexus made it that way as Boron said.
Old Feb 29, 2012 | 05:31 PM
Boron's Avatar
Boron
Worth chatting to a local dealership, in case it has learning capability.
I know the E65/E66 7 Series had that, and you could reset it so it learnt your style.
I'd be surprised if the GS did, but you never know unless you ask.
See if they can let you drive one of theirs, just to confirm/rule out yours not being as it should.
Old Feb 29, 2012 | 06:21 PM
pjay's Avatar
pjay
I have a similar issue, usually happens while driving behind a granny driver driving 40 in a 60, and Im stuck behind them. I just swap to semi, and it goes away. Pretty sure its just trying to keep me at low gear for fuel economy purposes, as described above.
Old Feb 29, 2012 | 06:35 PM
LADavidGS's Avatar
LADavidGS
thanks guys for your inputs. Coming from g35, i guess i expected a faster response..
aboturky83
Dec 19, 2021 06:34 AM
flattire
Performance
Feb 24, 2014 07:49 AM
donwan1802
May 5, 2009 05:03 PM
LexusIS-TL
Jul 3, 2007 12:27 AM
winsalem
Aug 26, 2005 12:12 PM
