what could the problems be?
Old Nov 24, 2011 | 11:15 AM
phamtastic's Avatar
phamtastic
Thanks a lot Steve for the info. I will call my service advisor tomorrow and let him know about the battery. I will keep you guys posted
Old Nov 24, 2011 | 01:35 PM
XxGoKoUxX's Avatar
XxGoKoUxX
very curious also LMK
Old Dec 10, 2011 | 06:43 PM
phamtastic's Avatar
phamtastic
I'm still car less during this holiday. Car has been at the dealer for two weeks now and still can't figured it out. This MAJOR problem sucks
Old Dec 10, 2011 | 07:28 PM
walid928's Avatar
walid928
if it says lost communication with power steering ecu then check wiring under the battery to the ecu..
if there is milk, then its blown,,, just replace had it once on mine and it was just wiring after replacing te battrey i smashed the connector to the ecu
here what i got
Old Dec 11, 2011 | 01:53 AM
sagikun's Avatar
sagikun
skip the diagnostics. it's a bad battery. btw most battery have 3 year warranty
Old Dec 11, 2011 | 09:15 AM
bklynjoker's Avatar
bklynjoker
From my knowledge of cars that's ur alternator 99%
Old Dec 12, 2011 | 07:18 PM
endlesslex's Avatar
endlesslex
this just happen to me last year. I ran sounds in my ride... dont know if it was that.. anyways.. it was the batt... after getting a new batt everthing back to it self.. hope it just ur batt.
Old Dec 15, 2011 | 02:35 PM
phamtastic's Avatar
phamtastic
Thanks for helping me guys. I will let my advisor know about this problem
Old Dec 21, 2011 | 07:04 PM
phamtastic's Avatar
phamtastic
finally got my car back! the problem was a loose wire on the navigation/rear camera harness. that one wire cause a chain reaction full of lights which cost me 1700 bucks. well at least i got my car back and thankful that there isn't any more problems.
Old Jan 7, 2012 | 10:38 PM
08lexus350's Avatar
08lexus350
Originally Posted by steviej
This was the problem with my 2006 GS. The battery was leaking gas that affected the power steering ECU which then set off a chain reaction of computer failure. All steering related items failed and the associated lights lit up, CHECK VSC showed up, CHECK 4WD,........everything but the check engine light. I was able to get the car to Lexus with the lights on and they were able to read the CAN-BUS codes (different from usual OBD coded associated with emissions and check engine light). In addition to my problems, the computer failures basically caused the ECUs to throw up. This in turn caused some "odditiies". My speedometer worked but the temperature guage dropped to C, the light behind the gear selector went out and the outside temperature would read "E".
When the battery was load tested, it failed. It had enough juice to always start the car, but it would heat up and emit a gas that affected the steering ECU and then start a chain reaction of computer related issues. The steering ECU is located directly under the battery case. Lexus is aware that there is a problem with the original Panasonic batteries.
Have your battery load tested and replaced if necessary.
steviej
when you changed the battery was everything back to normal? I have my temp reading E, ill have to check my battery and the ecu computer under it. thanks
Old Jan 16, 2012 | 08:54 PM
steviej's Avatar
steviej
The battery was swapped out on 10/18/2011 and I haven't had a single trouble light or incident since.
steviej
Gwhayduke
RX - 4th Gen (2016-2022)
24
Oct 13, 2019 04:18 PM
ns400h
Hybrid Technology
Jan 10, 2016 02:40 PM
vincentwc
Jul 29, 2014 01:33 AM
rodallg
Sep 28, 2012 09:43 PM
hoonami
GX - 1st Gen (2003-2009)
20
Jan 7, 2009 09:48 PM
