Climate Control Problem
Old Nov 11, 2011 | 08:47 PM
Avid1's Avatar
Avid1
Default Climate Control Problem
My 2007 GS 350 has been relatively problem free until now. At 88K, I noticed that my dual climate control system is now blowing out hot air on the passenger side while the driver side is functioning properly blowing cool air. Both driver and passenger side temps were set at 72 degrees with an exterior temp of 70 degrees. In order to balance the temps on both sides, I have to bring the passenger side way down to LO.
Has anyone experienced this issue?
Old Nov 11, 2011 | 09:06 PM
XxGoKoUxX's Avatar
XxGoKoUxX
it sounds like a sensor problem, your local dealer can fix this. If the vehicle is out of warranty, My gf/s stepdather's 4runner had the same problem, but with both sides, and the mechanic modified it somehow to be stuck on COLD only, no temperature adjustments available.
Old Nov 12, 2011 | 08:34 AM
Avid1's Avatar
Avid1
Thanks. I'd like to get the problem fixed instead of modifying or disabling the feature. Do you know how much I'd be looking at to replace a possible sensor?
Old Nov 12, 2011 | 11:01 AM
TWong350's Avatar
TWong350
CL Folding 10,000
This sounds like an air mix servo issue on the passenger side. Could be stuck or misadjusted (if it's even adjustable) since it seems to work fine if the temp is on LO.
Here's a illustration shown on the lower right of the photo. "Air mix control servomotor RH"
Old Nov 13, 2011 | 09:16 PM
Avid1's Avatar
Avid1
Interesting. I hope this is the case, and that it needs adjustment and not replacement. Thanks for the info.
Old Nov 16, 2011 | 01:06 PM
Avid1's Avatar
Avid1
Strangely, this problem has seemed to go away on its own. The passenger side climate control is back to normal. Hopefully, that's the end of it.
Old Nov 16, 2011 | 08:25 PM
XxGoKoUxX's Avatar
XxGoKoUxX
Congrats! Hope you're enjoying your car as much as I do
Old Nov 16, 2011 | 08:40 PM
Avid1's Avatar
Avid1
I've had my GS for almost 5 years now, and I am enjoying it as much as I did when it was new. The design of the 4th generation GS is a disappointment for me, so I'll be happy with mine for a while.
Old Nov 16, 2011 | 09:05 PM
XxGoKoUxX's Avatar
XxGoKoUxX
finally, someone feels the same way i do The only thing i enjoy so far about the 4th gen gs, is the rear passenger controls, now that is NEAT-O!
Old Nov 17, 2011 | 10:28 AM
TWong350's Avatar
TWong350
CL Folding 10,000
Nope, I agree with those statements too! Not into the 4GS at all.
Old Nov 29, 2011 | 10:32 PM
walid928's Avatar
walid928
exactly
carry out an activation test on them and see how they respond from 0-255 on the data list... if the value doesn't change at all then they are stuck...
using toyota tecstream or toyota intelligent tester only..
TechNut
NX - 1st Gen (2015-2021)
May 23, 2016 05:17 PM
T8LEX
Dec 9, 2010 07:08 AM
tommyLS460
Oct 1, 2005 07:09 PM
