will these wheels work?
Old Jul 27, 2011 | 02:31 PM
montz450's Avatar
montz450
Default will these wheels work?
i can get a used set of wheels and tires for excellent price ($600)and i was wondering if they would work . here are the specs:
f-20x8.5 +20 245/35 nittos 555
r-20x10 +30 275/30 nittos 555
thanks in advance.
Old Jul 27, 2011 | 02:41 PM
lkapimp216's Avatar
lkapimp216
Rims should work tires are over spec so you ll most likely rub on the liner may need to slightly shave the rear. Either way it's doable make it happen!
Old Jul 27, 2011 | 03:39 PM
rominl's Avatar
rominl
exclusive matchup
the front can be pretty bad problem
Old Jul 27, 2011 | 07:56 PM
montz450's Avatar
montz450
care to elaborate?
Old Jul 27, 2011 | 08:05 PM
1sWt2GS's Avatar
1sWt2GS
tires are going to rub most likely
Old Jul 27, 2011 | 09:58 PM
montz450's Avatar
montz450
front,rear or both?
Old Jul 27, 2011 | 11:06 PM
vakamon's Avatar
vakamon
Will have to push or hammer and dolly both front and rear fenders
They will both rub had my boy do mine and my offsets are +23 in front and +25 in the rear and the rear still rubs the front rubs sometimes but only on gnarly bumps or when you hit a dip in the road. I suggest getting a 265 in the rear if possible that's what I had to do I was running the same tire set up
Old Jul 27, 2011 | 11:15 PM
1sWt2GS's Avatar
1sWt2GS
both will, 245 much less than the 275 but will rub sometimes (when u hit a really big bump / dip)
275 are defintely going to rub unless u pull off some negative camber
Old Jul 27, 2011 | 11:43 PM
rominl's Avatar
rominl
exclusive matchup
the rear is close, if you take off the plastic trim you might be ok, but my guess is you will still rub a little
but the front, 8.5 +20 that's very aggressive, plus 245 (meaty) tires, that's not good combo. you will need a lot of work on your front fenders
Old Jul 28, 2011 | 04:44 AM
IXI187IXI's Avatar
IXI187IXI
its not the 245 thats going to kill him, its the height of the tire (35). i dont understand why people constantly want to run that size when its overspec'd and causes nothing but rubbing. with that front set up, you will certainly rub.
Old Jul 28, 2011 | 07:40 AM
msgs350's Avatar
msgs350
I think too many tire/rim shops recommend this tire (245/35 & 275/30) combo for 20" rims.
To OP, the rear will most likely rub if as well. To be safe on a 20x10 in the rear, you should look for +40 offset.
Old Jul 28, 2011 | 08:27 AM
JasGS350's Avatar
JasGS350
The front fenders will definitely need some work with that combo. I run a 235x30x20 tire with +28 on a 8.5 rim with a roll and still rub on big dips. The back will need to be rolled and pulled or shaved and pulled. I run a 255x30x20 tire with +38 on a 9.5 rim and I rolled and pulled and still rub where the quarter panel and rear bumper meet. I'm going to fix mine when I have my rear bumper repainted and the rear fenders fixed. FYI, don't roll the rears, you will crack the paint a little and get waves. Trust me.
Old Jul 28, 2011 | 09:39 AM
montz450's Avatar
montz450
one thing i forgot to say is the car will not be lowered. I will be stock height. Is this still gonna need some pull and shave?
Old Jul 28, 2011 | 11:15 AM
designo's Avatar
designo
Now that's a different story!
Old Jul 28, 2011 | 12:53 PM
lkapimp216's Avatar
lkapimp216
The GS looks soooooo much better lowered with a nice set of wheels. Keep hanging out on this site you ll lower it!
