When shifting to D-Mode...
Old Dec 16, 2010 | 02:38 PM
Rider's Avatar
Rider
Default When shifting to D-Mode...
There is a clunk sound when I shift to D-Mode everytime.. is this normal..., also the front driver tire is making a wobbling sound.. Time to visit the dealership?
Old Dec 16, 2010 | 03:32 PM
designo's Avatar
designo
Mahmood, I beleive that could be solved with a software reset! However, please keep in mind that our cars are short ratio 8 speed. Using the manual mode alot can do that to your car. Always make sure you dont downshift too many gears because our cars do not have rev matching feature, hence you will end up hurting your transmission!
Old Dec 17, 2010 | 03:19 AM
Rider's Avatar
Rider
I Hope thats just the case bro! Anyone can comment on the wobbling?
Old Dec 17, 2010 | 03:51 AM
lkapimp216's Avatar
lkapimp216
The wobbling could be many things! Is it wobbling all the time, while braking. Are all your lugs tight, wheels balanced, rims bent, tie rod end, was the rack and pinion recall performed, there are several possibilities. I have also found that if I don t fully press the brake pedal down when I shift into drive there I a slight delay and the car will catch causing a minor jolt
Old Dec 23, 2010 | 02:13 PM
Rider's Avatar
Rider
You were right, a reprogramming solved the issue
InfamousF
IS F (2008-2014)
Jun 13, 2017 11:37 AM
mindcrime
IS F (2008-2014)
23
Mar 18, 2016 12:22 PM
loccsta187
Jun 28, 2011 01:53 PM
zojirushi
IS F (2008-2014)
Apr 18, 2011 05:26 PM
ClaudiG
Dec 3, 2002 04:47 PM
