Rear stop light
Old Jul 17, 2010 | 02:46 AM
Lohus's Avatar
Lohus
Default Rear stop light
What device is located under the rear stop light on GS?
Old Jul 17, 2010 | 04:07 AM
GS350Lexus's Avatar
GS350Lexus
Its auto light sensor.
Old Jul 17, 2010 | 05:13 AM
Lohus's Avatar
Lohus
What about those under the windshield?
Old Jul 17, 2010 | 06:00 AM
GS350Lexus's Avatar
GS350Lexus
The sensor in middle of the dash, right under the rear view mirror? That little ball looking thingy? If that so, then its the auto climate control sensor. This all actually is stated in the manual.
Old Jul 17, 2010 | 06:13 AM
Lohus's Avatar
Lohus
Climate? Then why when I cover it the light turns on?
Old Jul 17, 2010 | 06:41 AM
passnu2's Avatar
passnu2
I'm pretty sure the rear is for the glare of the gauges if you have bright light coming from the rear window and the front is a sensor to put your interior lights into night mode.
Old Jul 17, 2010 | 09:43 AM
rominl's Avatar
rominl
exclusive matchup
the one in the rear under the 3rd brake light is light sensor for the rear, it's connect to help control the lighting on the dash when there's too much back light from the back of the car
on the dash the two "ball" thing that's light sensor to determine if the headlights should turn on or not and also the interior day/night lighting control
Old Jul 17, 2010 | 09:59 AM
Lohus's Avatar
Lohus
So it controls the illumination of the dashboard? I'am going to have my rear windows tinted and think about what to do with that sensor? Should I make a hole in a tint near it or not?
Old Jul 17, 2010 | 10:19 AM
passnu2's Avatar
passnu2
^ no because you will get less light with the tints.
Old Jul 17, 2010 | 10:29 AM
CAK 500's Avatar
CAK 500
Not the illumination exactly, but the opacity of the glass covering the gauge cluster. When the sensor detects bright light, it will cause the glass to change from transparent to slightly translucent. So, it appears slightly less crisp and bluish in order to eliminate glare on the glass.
I wouldn't make any alterations to your tint. If you want, you can just change the glass cluster setting sensitivity using the control in your drop down control panel.
Old Jul 17, 2010 | 10:35 AM
Lohus's Avatar
Lohus
Gauge cluster glass is electrochromic? Are you sure?
Old Jul 17, 2010 | 10:43 AM
CAK 500's Avatar
CAK 500
100% sure.
Old Jul 17, 2010 | 11:06 AM
Lohus's Avatar
Lohus
Ok, irrefragable answer.
BTW is that really useful?
Old Jul 17, 2010 | 12:04 PM
CAK 500's Avatar
CAK 500
I think it's a complex solution in search of a problem. I'd preferred they just got rid of my cassette deck.
vacarteres
Jan 9, 2019 08:51 PM
takimanpgt
Jul 23, 2015 02:43 AM
GatorGreg
GX - 1st Gen (2003-2009)
Sep 28, 2007 07:06 AM
triplecore
Aug 4, 2007 07:19 PM
enjun
Nov 17, 2006 12:55 PM
