Rim Question
Old Mar 1, 2010 | 08:04 PM
Bambigular's Avatar
Bambigular
Default Rim Question
This question may be dumb but I'm new to the Lexus scene and don't know. What the the off set mean. I know the size and with 19x8.5 but what is a + 45 front and +50 in the rear. And will IS 18' or 19' fit a 06 GS?? The bold pattern is the same so I'm assuming yes, but need some expert advice from members who been there. Thanks
Old Mar 1, 2010 | 10:41 PM
rominl's Avatar
rominl
exclusive matchup
http://www.tirerack.com/wheels/tech/...jsp?techid=101
https://www.rsracing.com/tech-wheel.html
tons of information on the internet.
IS does not have 19". they are all 18s, and yes they will fit on the GS (i am pretty sure)
if you talk about 19s, maybe you mean the ones from isf. if you have gs300, yes they will fit. if you have gs430, no they won't, they don't clear the calipers
Old Mar 2, 2010 | 01:49 AM
Lex Luga's Avatar
Lex Luga
this is probably a noob question too, but i was wondering if 20x8.5 wheels would fit on a 06 AWD GS that is stock. Would it fit and not mess up the TPMS or anything else?
Dying for these bbs rs-gt diamond black finish 20". So classy and would match the flint mica paint, just need to get this $$ up first.
Old Mar 2, 2010 | 04:11 AM
IXI187IXI's Avatar
IXI187IXI
20x8.5 is fine depending on the offset.
Old Mar 2, 2010 | 09:54 AM
Lex Luga's Avatar
Lex Luga
38mm offset. is that fine?
And another question. Ive been reading how people put larger width wheels in the back than the front (ie front 20x8.5 back 20x9.5). What is the purpose of that?
Apologies in advanced bc i noticed the person up top who asked a similar question, but i did not get the answer i was looking for in those links. Thanks!
Old Mar 2, 2010 | 10:14 AM
IXI187IXI's Avatar
IXI187IXI
yes 38 will be fine.
staggered is just for more traction. not really recommended on the awd though.
Old Mar 2, 2010 | 10:41 AM
Lex Luga's Avatar
Lex Luga
Thanks for the info
Old Mar 3, 2010 | 12:01 PM
girlracer's Avatar
girlracer
Yes, I'd trust Tire Rack
Old Mar 18, 2010 | 09:12 AM
Lex Luga's Avatar
Lex Luga
Sorry to ask such a similar question again but..
1) Would 20 x 9.5 wheels fit the gs 06.
2) would those wheels with the car lowered 1 inch affect the tpms and the ride?
3) Also can anyone recommend springs so the car will still have that Lexus feel and not be so rough.
Old Mar 18, 2010 | 09:35 AM
lkapimp216's Avatar
lkapimp216
tpms monitor the tire pressure in the tire unless you put tire sensors in your new wheels and program then to the car (which the dealer has to do) or you can take the sensors out of your factory wheels and have them put in to the new wheels. If you don t do this the tpms light will eventually come on and become aggrevating! as far as lowering im lowered and inch on stagger fitteds 22s and the ride is near factory granted bumps are more harsh, but i did extensive fender mods and had to cut plastic out of my wheel wells. 20s won t take as much mod work unless you lower further than an inch good luck
Old Apr 21, 2010 | 07:05 PM
Lex Luga's Avatar
Lex Luga
wondering if these Vossen Concave CV-1 will fit. I dont have the info on offsets.
i will have tein s tech springs on too.
http://www.vossenwheels.com/vossen-wheels-vvscv1.html
Old Apr 21, 2010 | 07:16 PM
passnu2's Avatar
passnu2
Yes they will fit. search this section and you can see what they look like on a GS
Old Apr 21, 2010 | 07:34 PM
Lex Luga's Avatar
Lex Luga
nice so they will fit with no fender work needing to be done? and what size tires would i be looking to get?
Old Apr 21, 2010 | 11:21 PM
rominl's Avatar
rominl
exclusive matchup
you can get cv1 to fit, they have some offset selections so you don't need fender work
Old Apr 22, 2010 | 04:18 AM
IXI187IXI's Avatar
IXI187IXI
if your staying with a 8.5 all around i would say a 38mm would work good. also for 20s you want a 245/30/20. people run 245/35s just for a little extra cushion but they run into rubbing problems on sharp turns.
