HELP!! How to remove push button start??
Old Jan 22, 2010 | 10:21 PM
[0350]'s Avatar
[0350]
Default HELP!! How to remove push button start??
Hi All,
I need help to remove my push button start, so I can run a wire to the back of it for my air suspension..
Does anyone know how to remove it?
Or does anyone know if I can connect the remote wire from the air compressor to another point in the car instead of trying to access the push start button..?
cheers.
Old Jan 23, 2010 | 02:53 AM
passnu2's Avatar
passnu2
my understanding, from having my remote start installed, the wires from the push start are really thin. I dont think you want to tap them as any kind of power source. Do you need a remote wire (on with car only) or a hot wire(always on)?
Old Jan 23, 2010 | 06:36 AM
worker's Avatar
worker
don't know why u want to mess with the button.
Old Jan 23, 2010 | 11:57 AM
BinaryJay's Avatar
BinaryJay
It's something to do with being on the other side of the equator, I think. Man, I wish I was in Aus right now, how's your summer going?
Old Jan 24, 2010 | 09:48 PM
[0350]'s Avatar
[0350]
Well I figured it out guys,
The weather here is boiling hot atm!!
Im running a hot wire now (running all the time) but with a switch, so it doesnt drain the battery.
Old Jan 25, 2010 | 12:27 AM
mysteryan's Avatar
mysteryan
Can't you tap the ACC on fuse?
Old Jan 25, 2010 | 04:52 AM
IXI187IXI's Avatar
IXI187IXI
why would you want to have it run all the time? when i use to have air ride, i had a rely with a seperate switch that i used to control my compressor to fill the tank.
Old Jan 27, 2010 | 03:08 AM
[0350]'s Avatar
[0350]
That is what i said... it has a switch.
Anyways I ended up hooking it up to the power to the cigarette lighter, so it comes on with ACC.
mitchell2u
Jul 4, 2016 01:10 PM
w8lifter21
Nov 29, 2010 08:25 AM
IS_Mine
Oct 12, 2006 01:59 PM
saltyreefs
Apr 18, 2006 11:46 PM
