Mark Levinson CD changer problem
Old Oct 19, 2009 | 08:21 AM
blckwidow's Avatar
blckwidow
Default Mark Levinson CD changer problem
Hey guys,
I started my car up the other day and realized my CDs don't play anymore. I thought it was the disc so I changed CDs but still the same problem. The screen shows that the disc is playing but there is no sound. I switched to the radio and it works just fine. I've tried to turn it off and restart my car, even made sure my battery had juice still, but nothing seems to work. Anyone having this problem?
Old Oct 19, 2009 | 10:40 AM
JasonGS's Avatar
JasonGS
Try a mp3 cd
Old Oct 19, 2009 | 10:57 AM
IXI187IXI's Avatar
IXI187IXI
were those cds working before? what year car?
Old Oct 19, 2009 | 11:11 AM
blckwidow's Avatar
blckwidow
2006. CDs were working before with no problems. I even thought that maybe it was because I was using burned CDs so I put in original CDs but no luck.
Old Oct 19, 2009 | 12:26 PM
mcyc's Avatar
mcyc
one of your connection is loose or the wire harness that connects to the amplifier is defective. I had that happen to me and they had to replace the whole harness.
Old Oct 19, 2009 | 01:39 PM
blckwidow's Avatar
blckwidow
Thanks for the info. Is this a do it yourself kinda thing or should I take it to the dealership???
Old Oct 19, 2009 | 01:41 PM
EyeKutr's Avatar
EyeKutr
if you are in warranty period, take it in, otherwise you can check connections yourself....it wont be at the amp since radio works right, it would make sense it may be behind the unit but even thatdoes not make sense I believe tuner and cd player are in one unit with output from there. If you are out of warranty it may just be time to get an ipod adapter and call it a day for CDs....
Old Jan 29, 2010 | 11:54 AM
blckwidow's Avatar
blckwidow
So I took this problem to the Lexus dealership and they were going to charge me $350 just to take my car apart and look at it! WTH!
Old Jan 29, 2010 | 12:41 PM
ivanz's Avatar
ivanz
Are you out of warranty? If you are, its pretty easy to take that part of the dash apart and check the connectors. In the worst case, you could spend some time to find the issue (I am guessing any changer issues would show up as an error on the screen).
If you are under warranty, there is no excuse for them to charge you. Even my Mitsubishi dealer doesn't charge to look at a problem. So just go to another dealer...
Old Jan 29, 2010 | 12:54 PM
blckwidow's Avatar
blckwidow
Yes, I'm out of warranty. Looks like I will be working on the car this weekend and seeing what is wrong with it when I take it apart. What should I be looking for? Just any wires that aren't connected right or may have gotten loose?
Old Jan 29, 2010 | 01:05 PM
ivanz's Avatar
ivanz
I would try to disconnect/reconnect everything relating to the CD changer<->headunit connections. Worth a try if something just fell out of its place...
Old Jan 29, 2010 | 01:08 PM
blckwidow's Avatar
blckwidow
Okay, I will definitely do that this weekend. Thanks for the help, I will update when I'm done.
Old Nov 28, 2012 | 12:33 PM
arni's Avatar
arni
Hey i was wondering were you able to figure out what went wrong with the changer? I have an 06 GS 300 and its not playing the cd, i can insert and take out, it just doesn't play at all, radio works fine.
Old Nov 28, 2012 | 06:10 PM
bigblack06's Avatar
bigblack06
Def. loose connection I had this same problem when I had the gs 300 it was a connection in the back that came loose over bumps. The track would be rolling but there was no sound I could listen to the radio but CDs would not play.
Old Nov 29, 2012 | 01:54 AM
DrexLex's Avatar
DrexLex
The reason the radio may play while the CD does not is because they use two different audio paths to the amp. The CD/DVD is digital, the radio is analog.
