Engine Vibrates Rough at Idle??
Old Oct 9, 2009 | 06:07 PM
erik535353's Avatar
erik535353
Default Engine Vibrates Rough at Idle??
Has anyone experienced this? When the car is at a light I can feel the engine
vibrating through the floor slightly and the door panel. While driving it's smooth a ice. Should I take it in or is this just another thing I have to live with while owning my Lexo?
Old Oct 9, 2009 | 07:01 PM
GS350Lexus's Avatar
GS350Lexus
I have the same problem. Not as much as the floor but on the door panels. When i took it in for service recently, i took a test drive with a mechanic. I mentioned that vibration n the electronic fuel injection sounds which is loud. His reply was these engines are designed like that. It will always vibrate little bit and be loud. So there is nothing u can do about it don't go changing spark plugs,filter,etc etc. Its there get used to it and try not to pay attention if it helps throw in in N position at lights.
Old Oct 10, 2009 | 07:33 AM
telmz1's Avatar
telmz1
After you take a ride with me in my dumped AWD, you won't feel yours anymore. My car vibrates so much that I need to drop it in neutral to make all the rattling stop.
Old Oct 10, 2009 | 07:42 AM
lkapimp216's Avatar
lkapimp216
change your air filter and vacuum out the air box then clean your throttle body with spray and a tooth brush I just did mine a couple of weeks ago definitely helped i also added a injection cleaner in with the fuel
Old Oct 10, 2009 | 08:03 AM
erik535353's Avatar
erik535353
I figured I was going to have to live with it, but I will definetley do the filter deal and the injection cleaner. Thanks.
Old Oct 10, 2009 | 08:05 AM
tromly's Avatar
tromly
+1, I used BG for the throttle body, worked great
Old Oct 10, 2009 | 08:49 AM
XxGoKoUxX's Avatar
XxGoKoUxX
mine's idles very quiet *shrugs*
Old Oct 10, 2009 | 11:21 AM
vladbph's Avatar
vladbph
I happens ocasionaly when engine is not at normal temperature yet. Ones it reaches it, I dont feel any vibrations.
Old Oct 10, 2009 | 11:59 AM
jtrue28's Avatar
jtrue28
yeah, my AWD vibrates a lot when it's cold. watch your RPMs and you'll notice the car idling at 1000-1100 while sitting at a light, but once the temp of the engine reaches about 40% of the guage the engine will settle down to the typical 600 RPMs.
Old Oct 10, 2009 | 03:38 PM
echelon's Avatar
echelon
CL Folding 500,000
I noticed this with my car and made sure to only use BP gas. The cheaper gas does not like my car at all. Of course I always run premium but they've been starting to put ethanol in the premium now.
Old Oct 10, 2009 | 07:25 PM
XxGoKoUxX's Avatar
XxGoKoUxX
i fill-up mobil, i use to fill up sams club gas until i found out i could get an extra 50 miles out of the car each fillup, and the price difference was only 5-10 cents
Old Oct 10, 2009 | 10:11 PM
lkapimp216's Avatar
lkapimp216
Quality gas definitely makes a huge difference in the way my car runs and mpg
Old Oct 11, 2009 | 03:22 PM
I8ABMR's Avatar
I8ABMR
I have the same issue when the car is running in the cooler temps of the winter. I have complainede to the dealership but they say there are no codes in the computer, but it still happens from time to time. I think its annoying. I ad the same issue with my G35 and they just increased the base rpm for the idle. Lexus acted like this was a big deal. I really dont think so
Old Oct 11, 2009 | 04:04 PM
lkapimp216's Avatar
lkapimp216
I really think cleaning the throttle will do it
Old Oct 11, 2009 | 04:43 PM
arnieosp's Avatar
arnieosp
How low did you go? Did you use springs or coilovers? Which ones? I am trying to figure out the least painful way of lowering the AWD.
