will these offsets fit an 06 GS3
Old Jul 18, 2009 | 07:18 AM
telmz1's Avatar
telmz1
Default will these offsets fit an 06 GS3
Please tell me these will fit an 06 GS3 lowered about 2" with coilovers no BBK:
Front - 20x8.5 +29
Rear - 20x9.5 +41
if no = damn!
if yes = will these tires work (I'm AWD): Front 245/35/20 & Rear 275/30/20. Do all fenders need to be cut or just the front?
Old Jul 18, 2009 | 12:12 PM
passnu2's Avatar
passnu2
offsets will work. I wonder if you will even need to do any fender mods in the rear. I honestly dont think you will need to. The front wont need it for sure.
Tires I am not sure. Someone else I am sure will know this.
what rims are you looking at??
Old Jul 18, 2009 | 12:21 PM
SNiiP3R's Avatar
SNiiP3R
Correct me if Im wrong, but I think with this setup the front wheels will stick out more than the rears. Might look funny....You most likely will have to shave/pull fenders to make it work. The rears I think are on the safe side, wont have to do any mods.
Old Jul 18, 2009 | 12:53 PM
telmz1's Avatar
telmz1
I'm curious about these 20" TrafficStar RTS. I don't think the existing tires will work - the rears need to get replaced regardless. I wonder if I bought these I can take them in somewhere to get refinished? Not sure where though.
https://www.clublexus.com/forums/whe...-for-sale.html
Old Jul 18, 2009 | 01:19 PM
passnu2's Avatar
passnu2
I think those would look good on the GS.
Old Jul 18, 2009 | 01:30 PM
telmz1's Avatar
telmz1
I think you are right. typically it should be 20X8.5 ET high 30s for the front & 20X10 ET high 40s for the rear.
I looked at the link again and the tires that are on the rears are 245/35/20 which are usually front size tires?
Old Jul 18, 2009 | 01:59 PM
passnu2's Avatar
passnu2
you can use a spacer in the rear When you get used you have to take them as they come.
They will work.
If you want the perfect set up IMO...
20x9 Front +35 (no fender mods required) I love how the car rides with a 9" rim on the front. I had the 8.5 on my last car and I feel it does make a difference.
I am 20x10.5 in the rear but I had to shave my rears for them to fit.
Old Jul 18, 2009 | 02:24 PM
telmz1's Avatar
telmz1
spacers....ah i forgot about them. i'll need to do research on those. i recall reading about some getting vibration issues - don't need anymore of those!
Old Jul 18, 2009 | 06:50 PM
passnu2's Avatar
passnu2
I had them on my car with my OEM for winter and NO issues. I had the Ichiba Type II. They are easy to install and take off. Hit up Nigel and he will take good care of you if you get these rims.
Old Jul 18, 2009 | 07:21 PM
telmz1's Avatar
telmz1
passnu2 - thanks for the help! i really appreciate it.
I was going through the vendor classified and came across these hub rings? I'm assuming i need them for the front but not the back because I'll be using spacers?
Old Jul 18, 2009 | 07:58 PM
passnu2's Avatar
passnu2
depends on the rims. Mine dont need hub rings.
Old Jul 18, 2009 | 10:22 PM
I8ABMR's Avatar
I8ABMR
I would be a little worried about the offset for the front
ksan
Nov 4, 2013 10:45 AM
meangene4
IS F (2008-2014)
15
Apr 19, 2012 02:00 PM
Measured
Dec 22, 2010 11:17 PM
rac2max
Jun 11, 2009 11:29 AM
eyecon7
VIP Style
Feb 6, 2009 02:53 PM
