3GS wheel thread
Old Feb 9, 2012 | 11:54 PM
  #736
sourwich's Avatar
sourwich
im new,my car is 06 rwd can i setup 245/35/20 and 275/35/20 and used f sport spring,any prolem?thanks
Old Feb 10, 2012 | 01:06 AM
  #737
Mesca's Avatar
Mesca
Both those tires are out of spec. I recommend going with 245/35/20 and 275/30/20 instead. The front is still overspec but only by a little. I have 235/35/20 and 275/30/20 to stay the right size.
Old Feb 10, 2012 | 09:06 AM
  #738
sourwich's Avatar
sourwich
if i make 235/35/20 and 275/30/20 is it ok with f sport spring?
Old Feb 10, 2012 | 12:37 PM
  #739
Mesca's Avatar
Mesca
Yup, that's perfectly fine.
Old Feb 12, 2012 | 10:32 PM
  #740
2nd2none's Avatar
2nd2none
Suspension: Tein Comfort Sport Coil Overs with EDFC
Wheels: Cordon CR-10
Front: 20x8.5/ +32 offset/ Michelin Pilot Sport 255/30/20
Rear: 20x10 / +38 offset/ MIchelin Pilot Sport 285/25/20
Rubs in the front when I turn left due to over spec tires. Will go with 245/30 next time up front
Old Feb 13, 2012 | 10:12 AM
  #741
NickL's Avatar
NickL
For those of you who's doing after market wheels, what do you do for TPMS?
Old Feb 13, 2012 | 11:45 AM
  #742
ryan78's Avatar
ryan78
Most aftermarket wheels are TPMS compatible. Someone makes a band type that will secure the TPMS to the barrel of the wheel without drilling. Either way, there is an option.
Old Feb 13, 2012 | 05:56 PM
  #743
timmy0tool's Avatar
timmy0tool
i know you have to have the dealer program it. i also heard you need to provide them with each individual TPMS number/code for them to be able to program? is this true? i don't want to dismount my tires just to check for a number on the TPMS? my new wheels already came with tires and TPMSs mounted.
Old Feb 14, 2012 | 03:55 AM
  #744
ryan78's Avatar
ryan78
Your car will have TPMS on the stock wheels. They do not need to be programed, as they already are. If you were to buy a second set of TPMS for the aftermarket wheel setup, i believe that there is a button below the dash that will allow you to sync up on your own. You will have to check the manual though. I am uncertain, as i have yet to install my second set. Or, you could do as most and install your existing set on the aftermarket wheels and ride the stocks in winter with no TPMS.
Old Feb 14, 2012 | 02:11 PM
  #745
gridlock13's Avatar
gridlock13
i bought a second set of TPMS sensors for my summer wheels. you don't need the code for each sensor but it makes the technician's job a whole lot easier and quicker. ryan78 is right in that there's a button on the left side under the glove box for 2 different sets of TPMS codes.
Old Feb 15, 2012 | 08:29 PM
  #746
sourwich's Avatar
sourwich
why they setup the front little higher then back (245/35/20-275/30/20),does it help anything?thanks
Old Feb 16, 2012 | 05:42 AM
  #747
little2576's Avatar
little2576
Does this button allow us to program the second set on our own without having to go to the dealer & get reprogrammed ?
Old Feb 16, 2012 | 06:52 AM
  #748
marquez617's Avatar
marquez617
Default Wheel Size 19s
19x8.5;9.5 +35-38 offset 5x114.3
hey guys im not that knowledgeable with rims sizes and offsets but would like to purchase a set of used rims and wondered if the above sizes would work on a GS 3rd gen, thanks again.
Old Feb 16, 2012 | 07:28 AM
  #749
Ice350's Avatar
Ice350
Those specs are fine.
Old Feb 20, 2012 | 09:48 AM
  #750
IXI187IXI's Avatar
IXI187IXI
why do you mean higher? the sidewall height of the 245/35 is only 1/8" taller than the 275/30
