3GS wheel thread
Old Mar 22, 2016 | 12:40 PM
  #1831
Mrcam216's Avatar
Mrcam216
Hey yawl. Question. Would a 245-35-20 and 285-30-20 cause any issues or set off any alarms on an 08 AWD GS.
I have 225-35-20 and 255-30-20 on now and they ran fine with no issue but the wheels were too narrow and the wheel stuck out so I want one a little wider. From what I saw on 1010tire.com they should be good. Just seeing if anyone else ran or is running that combo on an AWD.
Thanks!
Old Mar 25, 2016 | 08:07 PM
  #1832
baldwin22a's Avatar
baldwin22a
Default Rohana 19 wheels
Rohana 19 inch concave wheels
Old Mar 26, 2016 | 08:01 AM
  #1833
grayson73's Avatar
grayson73
Were you trying to post a pic?
Old Mar 26, 2016 | 04:16 PM
  #1834
baldwin22a's Avatar
baldwin22a
Yes i was trying, i just setup a username for 1st time so maybe i got to wait 30 days to post pics?.. thanks
Old Mar 27, 2016 | 03:41 PM
  #1835
calisuper's Avatar
calisuper
Thanks!
what tires were you running with your previous set up. i currently have the check awd error right now due to tires being too big of a difference. its my first set of wheels so im still new to this
Old Mar 27, 2016 | 04:09 PM
  #1836
msgs350's Avatar
msgs350
What are you running? For AWD, you should be around 1% max! If not, your car will think the traction is slipping and you will wear out your drive train.
You should run a 275/30-20 with the 245/35-20. I'm surprised you can fit a 285/30-20 without rubbing in the rear.
Old Mar 27, 2016 | 04:19 PM
  #1837
calisuper's Avatar
calisuper
Originally Posted by msgs350
If you're running 245-35-20 and 285-30-20 which looks like a variance of more than 3% , you will have issues. For AWD, you should be around 1% max! If not, your car will think the traction is slipping and you will wear out your drive train.
im currently running 20x9et38 225/30-20 and 20x10.5et45 255/35-20 on my set up :/ and my rear is close to rubbing, what is the best set up to stretch
Old Mar 27, 2016 | 04:26 PM
  #1838
msgs350's Avatar
msgs350
You are 6.77% off between front and back. I would remove those wheels if you are indeed AWD. You will do some damage, quickly.
Depends on how crazy strecth you want but you can go:
225/35-20 and 255/30-20
225/35-20 and 265/30-20
I've ran both on my AWD without any mechanical issues, just very rough ride and bent wheels due to being so stretched.
http://www.1010tires.com/Tools/Tire-...0R20/255-35R20
Old Mar 27, 2016 | 04:52 PM
  #1839
calisuper's Avatar
calisuper
dammit, haha if anyone has hook ups on tires please let me know
Old Mar 28, 2016 | 05:51 AM
  #1840
grayson73's Avatar
grayson73
Actually, 245/35/20 has exactly the same circumference and diameter as 285/30/20. 275/30/20 is 1.8% smaller in circumference.
Old Mar 28, 2016 | 05:56 AM
  #1841
grayson73's Avatar
grayson73
What do you think about running 235/35/20 all the way around with 8.5" rims? Would that be stretched? I don't want bent wheels nor rough ride.
Old Mar 28, 2016 | 06:34 AM
  #1842
msgs350's Avatar
msgs350
If that's, what it is, my mistake. 285/30-20 is a huge tire.
To me, it would look good. Since you seem to be on the cautious side, make sure the load rating for that tire size is sufficient.
Old Mar 28, 2016 | 11:28 PM
  #1843
Mesca's Avatar
Mesca
That's a good size if you want the most meat on a tire without going over 3% of original stock diameter. Anything more puts excess stress on the drivetrain.
Old Mar 29, 2016 | 10:52 AM
  #1844
grayson73's Avatar
grayson73
Thanks, guys. If going 235/35/20, what are the pros/cons of going with 8", 8.5", 9", and 9.5" wheel width in terms of comfort, rim protection, and look?
Old Mar 29, 2016 | 08:08 PM
  #1845
VDMTom's Avatar
VDMTom
Just did a shoot for SSR Wheels.. My GS now has 19" Professor MS3 in SBC Disk / Polish Lip
