Awd?
Old May 18, 2009 | 06:53 PM
Leonard15's Avatar
Leonard15
Default Awd?
Hi guys I have a 2009 GS 350 AWD and was wondering if the car always runs in AWD mode or is there a switch to make if run either on the rear wheels or front wheels.
Old May 18, 2009 | 07:27 PM
kyang91's Avatar
kyang91
I am pretty sure that with the GS AWD system it is always on but it is rear biased with a 40/60 power split. There isn't a switch like the new RX where you can change to 2WD.
Old May 18, 2009 | 07:54 PM
Yang1815's Avatar
Yang1815
There is no switch. Usually only 4WD systems have a switch.
Old May 18, 2009 | 08:00 PM
LexFather
Guest
Posts: n/a
Like a proper luxury/sporty car, the GS has a 30/70 RWD bias split during normal driving. When there is slippage detected, the power is transfered as appropriate.
Old May 19, 2009 | 06:29 AM
The G Man's Avatar
The G Man
The new RX is always in AWD mode too, the switch is to lock in all 4 wheels. The system in the RX is different from the GS. The RX use an electro-magnetic clutch pak to save weight. The AWD system in the RX only send torque to the rear wheel when accelarating or when the front wheel slips.
MNSC3
Mar 6, 2024 01:10 PM
noosense00
Feb 21, 2020 07:16 PM
cflutist
RX - 3rd Gen (2010-2015)
12
Jan 18, 2014 02:36 PM
barabus
May 18, 2006 05:31 AM
blazerbeam
RX - 1st Gen (1999-2003)
Jan 13, 2005 08:45 PM
