Hey everyone,
My GS450h is here, and im loving every bit of it, EXCEPT the bluetooth system!
I have an iPhone 3G, and although clarity is excellent in the car, the recipient or caller has difficulty hearing me clearly.
I did a little poking around, and found a way to access the service menu, in which you are able to adjust incoming and outgoing volume, as well as this little option that says: "voice quality". As i do not have any difficulty hearing on my end, i left the incoming volume as "0", whilst the outgoing volume is now set to "5". I did some test calls and apparently the recipients can now hear me much louder, however there is now the complaint that my voice seems to have too much treble. May i know what are the recommended settings?
Whilst making adjustments in the service menu, i accidentally pressed 9 under the "voice quality set", and i'm now lost as to what the default setting was. Could someone with a 09 Lexus GS, please advice as to what this number should be as default?
Thank you all in advance!
Quote:
that didn't answer his question. Originally Posted by Modeler
My advice is to stop poking where you're not supposed to!
to OP: go back to the dealer and have them adjust the settings.
