20's and rubbing
Old Mar 7, 2008 | 01:55 AM
safricags's Avatar
safricags
Default 20's and rubbing
if i run 245/30/20 with a 35 offset, will i rub????
or would it be safer to run 235/30/20
experts please
Old Mar 7, 2008 | 06:33 AM
lexgs350's Avatar
lexgs350
35 offset with 2ppl in the back will rub ............i tried
Old Mar 7, 2008 | 06:51 AM
safricags's Avatar
safricags
40 offset, 245/30/20 9.5' lip yes or no or rather 9' max
no rubbing problems with 40 offset??
Old Mar 7, 2008 | 10:30 AM
carlos's Avatar
carlos
umm.. the width of the wheel would be needed to determine if it will rub or not.
also, if its for the front or the rear.
Old Mar 7, 2008 | 12:13 PM
ek9vboi's Avatar
ek9vboi
My rears are 20x10 with a 41 offset. No rubbing at all, no mods either. I was thinking about running a 5mm spacer to get it more flush, given I will prolly have to shave the lip on the quarter panel a little. With the 41 offset now, I have just about 3-4mm more to get it flush.
Old Mar 7, 2008 | 01:42 PM
socalJD's Avatar
socalJD
Originally Posted by ek9vboi
My rears are 20x10 with a 41 offset. No rubbing at all, no mods either...
Looks like you're lowered - don't you have springs or coilovers ???
Old Mar 7, 2008 | 02:32 PM
ek9vboi's Avatar
ek9vboi
Springs. When you lower the car, it cambers the wheels in, thus eliminating some rubbing problems. When they had test fitted the wheels on before the drop, they were sticking out a little and I was worried but then after the drop everything was fine.
Old Mar 9, 2008 | 09:50 AM
AlterZgo's Avatar
AlterZgo
Theoretically, lowering the car does not eliminate rubbing. It is true that a lowered car will have more negative camber than a stock height car. However, the camber comes from the wheel traveling through it's normal suspension arc. Regardless of whether the car is lowered or not, it will go through that same suspension travel path.
Think about it this way - if you have a stock car and load the trunk with bags of concrete dropping the back end 1.5", it will camber exactly as much as if you lowered the car with 1.5" lowering springs in the back.
If your car was rubbing before being lowered, it will not rub less after being lowered.
Old Mar 9, 2008 | 09:55 PM
I8ABMR's Avatar
I8ABMR
I have tein h techs with 40 offset tsw wheels 20x8.5 front and 20x10 rear with 245/30 front and 275/30 rear and absolutely no rubbing. The offset is key for rubbing. Also you are going to want to keep the new wheel set up close to stock diameter so stick witrh 245/30 or something close. I dont like the idea of putting a narrower tire than the manufacturer already did. It should be the same or larger. generally larger. So I would go with 245/30. In fact next time I will try 255/30 in the front. They use this size alot at local dealerships anf it looks very nice and gives you a slightly higher amont of grip relative to the 245. good luck
Old Mar 10, 2008 | 05:32 PM
DDV1's Avatar
DDV1
Hey just bought a 2007 gs 430 and i was looking for some rims. just woundering if 20x8.5 245/35/20 with a 35 offset would rub??
Thanks
Old Mar 10, 2008 | 07:45 PM
Heng350's Avatar
Heng350
Aww man considering my offset on my rims coming in next month is 20x9F and 20x10R with +32 offset will rub like no other Well at least it will look nice :P Hope Rolling / Flaring / Cutting my fenders fix it. <---saying i need all 3
Old Mar 10, 2008 | 08:54 PM
6MTIS250's Avatar
6MTIS250
my AME are 19x10 +35 245/40/19 and it rub , but abit of fender roll will fix it
just got my BBK on now have 5mm spacer on rear and rub carzy ...............
lowering on Air sus
Old Mar 11, 2008 | 05:22 AM
carlos's Avatar
carlos
lowering on Air sus
got pictures?
kingkai23
Suspension and Brakes
Jul 28, 2009 06:31 PM
thomastan
Mar 24, 2009 05:46 PM
KIEUGS3
Jun 6, 2008 01:28 PM
AK-47
Mar 17, 2008 01:04 PM
alxmorse
Jul 28, 2005 12:53 AM
