TSIB Pads/Squealing
Old Mar 20, 2009 | 11:00 PM
  #46
ww50th's Avatar
ww50th
I had my pads replaced per the TSB on Mar 4th. I did the bed in proceedure as suggested by Whlkev and so far the dust generation is far less than before and there is no squeel. It seems to correct both problems.
Old Mar 21, 2009 | 06:03 PM
  #47
killahb36's Avatar
killahb36
Originally Posted by The G Man
Killahb36, did they replace it with the low dust pads?
i had these two done
04945-22152 shim kit, anti squeal
04465-30410 pad kit, disc brake
i think this is consistant with what others have had done, still doing good
Old Jun 23, 2009 | 04:22 PM
  #48
sanguine's Avatar
sanguine
Default squealing came back
So I had my brakes replaced a few months ago. I didn't replace it with the dustless pads as I didn't mind the extra dust. What I noticed was after I washed my car, the squealing came back! I am going try to bed-in the brakes and hopefully it will go away otherwise I will have to take it back to the dealership. What I do notice though is the squealing is getting more consistent so I shouldn't have any problems proving to the dealership what embarassment I face everytime I slow down for a light. The squealing also seems to be much louder.
This squealing only takes place when the braking is light and speed is very low (parking lot speeds). I am hoping it is just some residue from my wash that is causing the brakes but we will see
Old Jun 23, 2009 | 11:33 PM
  #49
I8ABMR's Avatar
I8ABMR
damn I didnt know this brake noise issue was so wide spread.
Old Jun 24, 2009 | 06:59 AM
  #50
beez43's Avatar
beez43
i had it too before but i switched out my rotors to some aftermarket powerslot ones and did the brake pads to the ebc red stuff.. no noise so far and i can stop with much more confidence.. there is a significant amount of more bite than stock.. however, its nothing like my supra bbk i had on the last gs...
Old Jun 29, 2009 | 02:02 PM
  #51
sanguine's Avatar
sanguine
How much did it cost to swap it out? I may considering going that route rather than going to the dealership every several months for new pads. I tried rebedding the brakes, the squeak went away for a day then came back with a vengence and squealed everytime I stopped in stop-n-go traffic. It was so embarassing. But earlier today when I'm driving I don't hear anything, WTH!! So I'm hoping one day I can get it squeaking then run to the dealership and prove it, otherwise they think I'm crazy and making stuff up. This is becoming a headache, I don't mind the suttle rattles in the dash, but brakes squealing is so terrible.
Old Jun 29, 2009 | 02:09 PM
  #52
beez43's Avatar
beez43
well too bad youre all the way out in the west coast friend.. i envy you however... i actually did both sides myself.. each side takes only about 15-20 minutes at most.. pretty easy mod and um.. how did you rebed the brakes? or the pads? i would replace your rotors and pads if you were near me but unfortunately thats not the case.. im sure if you buy the parts, ~300 bucks or so for rotors and pads, then a shop shouldnt charge you more than a 100.. since itll only take less than an hour or so..
Old Jul 1, 2009 | 01:16 PM
  #53
sanguine's Avatar
sanguine
I followed a bed-in procedure from a link I found from this site. It consist of braking hard from 60mph to 10 mph about 8 times to smooth out the brake pads. Funny thing is, the day after I did it, I didn't hear squealing, the second day, I heard lots of squealing. The past two days, I haven't heard it squeal at all. I'm not sure what is causing the squeal because it is truly random. It happens during the day/night, hot/cold. I'm hoping it fixed itself but I doubt it. My goal is to make the squealing consistent so the dealer will have to resolve it. Until then, I will just look crazy not being able to produce the sound at the dealership. Since it is under warranty I want the dealership to take care of it. After I wore out my brakes, I will look seriously into aftermarket parts.
Old Jul 1, 2009 | 01:36 PM
  #54
beez43's Avatar
beez43
wow i must be an idiot because i did not know anything about a bedding in process... wish i would have done that.. but im sure its good now.. no squeals and its already been 2 weeks!!!
Old Jul 19, 2009 | 03:47 PM
  #55
sanguine's Avatar
sanguine
The squeals still exist, I am hoping it is consistent so I can take it back to the dealership to have it checked out. I checked online for several reasons and solutions for the squealing. One suggested I spray some brake lubricant to prevent the squealing but I feel that it shouldn't squeal to begin with. I've tried braking hard several times to burn off the film but that seems like only a temporary fix.
Old Jul 19, 2009 | 03:58 PM
  #56
jwin's Avatar
jwin
The TSIB brake pad start to wear down they will start to squeals after about 6 months. That what happened to mine.
Old Jul 19, 2009 | 04:15 PM
  #57
sanguine's Avatar
sanguine
Are you just waiting to change yours out? I don't know how to live with it, it is so embarassing. It produces an ear screeching sound, it isn't subtle, it turns heads everytime I put the car to a complete stop.
Old Jul 26, 2009 | 01:30 PM
  #58
sanguine's Avatar
sanguine
So I took my car to the dealership Saturday morning. I got a call from the advisor stating that they could not reproduce the squealing (which I could not believe since it was happening almost all the time). So I went and picked up the car and tried to get the brakes to squeal and I couldn't. I left the dealership frustrated but at the same time optimistic that possibly the squealing fixed itself. As soon as I drove into my parking lot, it started to act up again. Determined, I drove back to the dealership and made it squeal extremely loud several times around the dealership. They ended up replacing my pads yet again, this time w/ the dustless pads. If the outcome is going to be similar with other members on the board, it sounds like I will have to take it back a few months for another set. Does anyone know much about the lemon law? If they replace the pads 3 times and it stilll isn't fixed, isn't it a lemon? Well, officially with Lexus, this will be my first set of pads, even though technically it is my second. I guess I can brake with confidence until I hear the noise again.
Old Jul 26, 2009 | 11:03 PM
  #59
vladbph's Avatar
vladbph
So true.... for few month I was happy and now it started again
Old Jul 27, 2009 | 10:17 AM
  #60
BKE420's Avatar
BKE420
don't know if this has ever been posted...but this is what i'm experiencing:
http://www.youtube.com/watch?v=Ca-UmSsIaM0
that's why i'm pursuing aftermarket pads.
fortitude
Jan 14, 2016 10:14 AM
lexus0707
Suspension and Brakes
Apr 20, 2014 03:50 PM
hybridanim
Apr 5, 2011 05:22 PM
mark98ls40
Oct 14, 2010 06:27 PM
tocoolexus
Nov 28, 2001 08:23 AM
