First oil change and making a DIY
Old Jan 8, 2008 | 04:50 PM
Cut-Throat's Avatar
Cut-Throat
Veteran: Navy
Originally Posted by GiSmo350
Your not very bright are you. Why would I own a Lexus dealership but subscribe to a do it yourself oil change thread? Im going to start doing my own oil changes as well. Just stated the obvious. No need to get ur panties all up in a bunch.
If you have to ask the question, then I would guess you're not very bright.
Old Jan 8, 2008 | 08:16 PM
GiSmo350's Avatar
GiSmo350
OK?
Old Feb 5, 2008 | 11:59 PM
moolman's Avatar
moolman
Well folks, back from my long vacation and I was about to do the oil change DIY, ordered up the filter and bought the oil. I did some extensive research on the web and it seems from two independent sources that Toyota does indeed use a special break in oil. When they did the oil analysis on new engines, the Moly count was through the roof, indicating that oil has extra Moly to help with break in. If that is the case, it's best to leave the oil in the car until 5K and not change it at 1K. Can anybody else confirm this? I haven't driven the car much since I was on vacation I barely have 700 miles on it now.
Old Feb 6, 2008 | 04:17 PM
socalJD's Avatar
socalJD
^ True. Search the 2IS forum, many owners had UOAs done on their 1st oil change at 5k. Toyota as well as Honda uses dino oil from the factory with extra moly for initial break-in. You OCD types can still change your oil at 1k, the extra moly is not a deal breaker since normal engine break-in is apprx 680 miles. Lexus supposedly 'breaks in' each engine at the factory before installing, so formal break-in for the engine is not what it was like 10 yrs ago. FWIW I'm sticking with 5k OCIs and 5w-30 dino oil, but that's just me, and certainly do not want to start a holy war over oil types, weights and change intervals. . .
Old Feb 6, 2008 | 06:54 PM
kingofire's Avatar
kingofire
Old wives tale about break-in oil. I did an oil analysis on my dads ES350 with 900 miles and there was nothing out of the oridinary with Moly, Zinc or Phosphorous. Looking at the report now and Moly is 51, Zinc is 726 and Phos is 735. Only thing out of ordinary was the high amount of Calcium which was 2626. My insolubles were high which meant lots of crap in the oil so it was good that i drained it.
Old Feb 8, 2008 | 12:02 AM
SilverSprt's Avatar
SilverSprt
Man, I just performed an oil change on my GS350 today..had I known, I would have taken pics and all..maybe next time.
Old Feb 15, 2008 | 02:39 AM
moolman's Avatar
moolman
An update for those that do oil changes. The part number for the GS350 has changed to Part # 04152-YZZA5 from Part # 04152-YZZA3, the reason stated is the the o-rings are of a stronger material. Once the A3's are all gone, only the A5 will be sold. The A5 box contains filters stamped A3, so they kept the filter and just changed the o-ring package. I just ordered a couple of filters from a vendor on clublexus.
Old Feb 15, 2008 | 05:08 AM
Cut-Throat's Avatar
Cut-Throat
Veteran: Navy
Let me be specific. The first gasket they used was defective. They called the Parts Place and had them deliver a new one. Yes the part is hard to get and is not available, see the original posters comment.
Well, this explains why my 'cheapie' oil change place had trouble with my oil filter. It was not their fault at all! - Turned out to be a defective O ring!
Old May 27, 2008 | 09:08 PM
i3urton's Avatar
i3urton
where are you guys buying the oil filter from?? local shops pepboys/autozone or online???
i find them online but i hate shipping... who are u guys doing it??? any input would be appreciated..
block232
NX - 1st Gen (2015-2021)
23
Feb 18, 2020 07:57 AM
stas2007
May 12, 2012 01:57 PM
poorbong
IS F (2008-2014)
Jun 22, 2011 06:47 AM
IS350atWOT
IS F (2008-2014)
Aug 17, 2010 01:54 PM
