Driver side AFS doesnt work
Old Aug 19, 2007 | 10:37 AM
ttran076's Avatar
ttran076
Default Driver side AFS doesnt work
My driver side headlight does not adjust when I turn the car on. What I mean is that when you first turn on the car, both lights turn down and auto adjust when leveled out. Now when I do turn on my car only the passenger side turns down and auto adjust. Has anyone ran into this issue?? I believe this started when I hit a pothole pretty hard yesterday.
Old Aug 19, 2007 | 12:45 PM
AlBoston's Avatar
AlBoston
i see u have modded ur suspension. Thats the first thing i'd check, level sensors.
Old Aug 19, 2007 | 08:11 PM
ttran076's Avatar
ttran076
The level sensors are in the rear right?
Old Aug 20, 2007 | 09:19 AM
slk_dds's Avatar
slk_dds
I think this is what you are looking for, hope this helps.
https://www.clublexus.com/forums/sho...d.php?t=183257
Old Sep 2, 2007 | 09:36 PM
ttran076's Avatar
ttran076
I brought my car to get it checked out by the dealer and they said nothing was wrong with it. The AFS light does not flash but the driver side headlight still does not work properly. I can see it especially at night when I turn on the car. The driver side barely moves down and then get stuck, while the passenger side fully goes down. But they do the both come back up and level out. Does anyone know what might be wrong. Or does anyone know a shop in the OC that might able to figure this out. Thanks.
Old May 26, 2008 | 07:23 PM
eric_r_ho's Avatar
eric_r_ho
I have the same problem w/ my PASSENGER side headlight..did you ever get this resolved?
Old May 26, 2008 | 07:45 PM
**FL Lex**'s Avatar
**FL Lex**
I've read of others having this same issue on here, going to do search now for it
Old May 26, 2008 | 07:46 PM
**FL Lex**'s Avatar
**FL Lex**
Is your Adaptive Front Lighting Indicator (AFS) going off on the dash?
Old May 26, 2008 | 11:31 PM
eric_r_ho's Avatar
eric_r_ho
Actually no, it's perfectly fine. I even disabled it and restarted the car a couple times. Nothing. I'm prettty sad about it man..I bought this car thinking I wouldn't have to bring it back to the dealer EVER again..
THanks for the help man, I couldn't find much resolve on this website. There are people who have the problem but no fixes..
Old May 29, 2008 | 06:33 PM
eric_r_ho's Avatar
eric_r_ho
Anybody w/ some input?
Old May 29, 2008 | 08:32 PM
TXprfrmnce's Avatar
TXprfrmnce
Question: Other than the start up, is it functioning properly? i.e. Is it turning along with the turns in the road as you drive and does it respond when you are on an incline or decline?
Old May 30, 2008 | 06:45 PM
eric_r_ho's Avatar
eric_r_ho
No it doesn't turn at all whenever I make a right..It's just stuck facing upwards. On the way to the dealer right now, I'll get back to you.
Old Jun 1, 2008 | 01:07 AM
eric_r_ho's Avatar
eric_r_ho
Well then. I guess it was just out of adjustment. I don't undersatnd how it lost the centered position anyway. It doesn't make any sense. I didn't touch it at all nor did I hit a pothole/speedbump. oh well. it's fixed now..hope it doesn't happen again.
Sporkit
Feb 7, 2015 03:54 PM
RamshakleZ
Sep 26, 2012 07:35 AM
phatz
Jan 8, 2010 11:29 AM
PhilipMSPT
Nov 16, 2008 09:24 AM
Enginerd
Aug 8, 2008 10:04 AM
