Low dust break pads - Front or All?
Old Jul 30, 2007 | 08:20 AM
StevenC56's Avatar
StevenC56
Thumbs up OK With Factory Pads
We're OK with the factory pads too. I would rather have the best possible braking performance and no noise issues. We wash the car weekly and the brake dust is pretty minimal compared to our BMW and these wheels are SO much easier to clean. For me, if it's not broken-Don't fix it.
Old Jul 30, 2007 | 10:12 AM
twister's Avatar
twister
I had my dustless breaks for 3k miles already. Probably first couple of hundred miles I felt pressing break pedal a little bit harder than usual. Than it went back to the way it was before. Trust me, you will not be sacrificing any performance or safety. Just think about it, do you think a company that requires you to hit "I agree" and disabling use of NAV dest changes while you are driving will allow compromising their reputation by making your car unsafe?
Old Jul 30, 2007 | 11:57 AM
Yang1815's Avatar
Yang1815
Seriously, at 1,800 miles... The difference should be minimal. However, if you have 10,000 miles then get the new pads? The service department is NOT going to resurface or do anything to do the rotors which means with the brand new pads in, you'll probably only have 70-80% of contact surface compared to the original pads and therefore, you will notice a decrease in stopping power (having to push deeper to achieve the same feel in braking). However, after 5,000 miles of driving on the new pads, they should have set in and once again, 100% contact and should perform the same. If there's any different it'd be negligible.
Old Jul 30, 2007 | 03:15 PM
memasterac's Avatar
memasterac
Thanks all. Two front pads tomorrow and also the service manager will get back to me (he said he needs to call the corporate ) on changing the Yokohama tires.
Old Jul 30, 2007 | 04:16 PM
starstreak's Avatar
starstreak
if you get them to swap tires, let me know how you did that.
Old Aug 1, 2007 | 12:33 PM
Les Apt's Avatar
Les Apt
Wink
Originally Posted by reggiek
I had only 1K on mine when it was done. Good mechanics never change pads without either resurfacing rotors or changing them. You get sqeaky brakes if you don't change.....most of the time.
Really?
If I have no pedal pulsation, I put in new pads and go on my way. Why cut good metal and shorten the lifespan of the rotor? If the rotor is true, there is no pedal pulsation, and there are no grooves in the rotor, there exists no reason to cut them.
I usually get three sets of pads before I have to replace rotors do to thickness limitation.
Been doing it that way for 30 years...
Old Aug 3, 2007 | 08:43 AM
memasterac's Avatar
memasterac
Default Update
Got my cars back last night while enjoying the RX400h as a loaner for the past two days...
1. The front break pads are changed with the low dust. The rotors are left untouched according to the service manager. (current ODO: 4250)
2. Got Michelin Pilot Sport A/S, set of four. It's quiet as my initial impression, like the Yoko's when they were brand new. I'll give 4~5K miles to judge if the quietness holds up. No realignment done according to the service manager.
oblivionis
Suspension and Brakes
14
Sep 21, 2010 09:16 AM
cpr greg
Dec 2, 2009 09:48 AM
luxury1
Maintenance
15
Sep 15, 2008 06:58 AM
Hartawan
Wheels, Tires & Brakes Forum
Jun 27, 2008 01:59 PM
GS300Rich
Performance
Jul 13, 2007 01:40 PM
