Burning DVD-A with Toast
Old Feb 6, 2007 | 04:09 PM
freight400's Avatar
freight400
Default Burning DVD-A with Toast
I am in need of some help with burning DVD-A with Toast 8.
I have converted a group of songs into .wav and .aiff. I can then import them to toast then burn to DVD.
When I play the DVD in the car, the system reads it as a DVD-Video. The songs play and sound really good, but the problem is with track advance. I have to advance to the next song manually, nor does it advance to the next chapter without stopping and using parking brake, DVD hack is not an option.
If anyone has burned DVD-A I would greatly appreciate any help.
Also, is there a way to change the lighting on the steering wheel controls? I think mine are too faint.
Thanks
Marc
Old Feb 6, 2007 | 04:15 PM
Abear's Avatar
Abear
CL Folding 200,000
The car doesnt play MP3 CDs?
I have burned a few MP3 DVDs and used them on my aftermarket HU in my 1st gen. I have no experience with Toast, I use nero and it works pretty well.
Old Feb 6, 2007 | 05:33 PM
Balnk's Avatar
Balnk
Abear....
He isnt talking about MP3's. Where did you come up with that?
He's asking about DVD-Audio. I'm sorry I am of no help in regards
to your questions.
Balnk
Old Feb 6, 2007 | 07:09 PM
sbrown02's Avatar
sbrown02
Freight - I think you're plowing new ground here for most of us. I tried last saturday to find a post that explained how to burn DVD-Audio files and I'm still not sure how to do it. Are you on a PC or Mac? All I know is I have PC with several thousand MP3 files that I'd love to burn to DVD (so I can fit more on the disk) instead of CD and I haven't figured it out yet.
One more thing. In order to make it worth my time I'd want the DVD to have folders for each Artist or Genre of music, cause if its just a list of 2000 songs one after the other, to me that's pretty useless.
So bottom line, if anybody else has figured out how to get MP3's to DVD-Audio in a directory structure that the ML system will read, please share.
Thanks
Old Feb 6, 2007 | 08:32 PM
2thfixr's Avatar
2thfixr
DVD-Audio is not the same as MP3 data files burned onto a DVD. I believe the original poster is burning audio tracks onto a DVD. The files are not compressed and at the same time, there is room for more than 80 minutes of music.
Old Feb 7, 2007 | 04:37 AM
kaewen's Avatar
kaewen
Hi freight400!
I've sucessfully burnt DVD-A with my toast with menu, chapters, and even a shuffle function. You do not need to convert them to wav or aiff.. Just drag and drop from itunes. It works wonders!
However, I'm also experienceing the same thing on the track advance.. Sometimes, it will work fine but whenever i skip a track, it starts to give all sorts of issues... playing the same track over and over again, or it will auto skip back 5 tracks and plays from there... arghhh...
My best advice is not to forward any tracks thru your steering wheel when the DVD is playing. Also.. i hate it when an incoming call cause the DVD to start from the begining of the track.. lol
One tip... check the Auto-play on insert funtion on your toast. So you dont have to park your car everytime u change to the DVD
Old Feb 7, 2007 | 10:49 AM
sbrown02's Avatar
sbrown02
Originally Posted by kaewen
Hi freight400!
kaewen - If you don't mind, please provide the specifics on how you're doing this. For example, if you could answer the following questions that would be great:
1) What type (DVD -R, +R, RW, etc.) and brand (Memorex, etc.) of DVD disk are you using?
2) What music file format (wav, mp3, etc.) are you actually burning to the disk?
3) What type of computer (MAC or PC) and OS (XP, Max OS10, etc.) and DVD burner (Sony model XYZ, etc.) are you using?
4) What specific settings are you using in Toast to burn the DVD? If you have any screen shots that would be very helpful.
5) Just curious but how many Gigabytes (GB's), how many music files and if you have it how many hours or minutes of music are you able to burn to one DVD?
Thanks for the help.
Old Feb 7, 2007 | 07:44 PM
freight400's Avatar
freight400
Kaewen, looks like we are in the same boat with the track advance stuff. I tried dragging and dropping files directly from itunes, but it did not work. I burn a cd and import back using the .aiff format.
I think I need to play around with toast some more.
I am using a mac and using dvd-r. I purchase the complete set of U2 songs from itunes, 443 songs and was able to fit all of them on one DVD. It sounds great, but the track advance is a thorn in my side I need to get rid of.
I tried using mp3, but that just didn't work. The uncompressed format of .wav and .aiff is needed.
Old Feb 7, 2007 | 08:04 PM
kaewen's Avatar
kaewen
I'm using Verbatim Lightscribe DVD+R, but others worked fine too.
www.lightscribe.com
I dont really know as the imac, toast and itunes does all the conversion for me. All I know is that I have mp3 in my itunes and it auto decode-encodes to DVD-A and burns it for me.
I'm using a imac 20" with the Intel processor. I have a built in SuperDrive as they call it Also an external Lacie Lightscribe drive on my Firewire 800.
But the whole process takes more than 3 hours.. to encode the music files, build the DVD menu and such. Burning time took less than 15mins.
tada
I was able to get 40hrs of music on my DVD-A. Had around 7 chapters, each with 99 tracks in them.
Old Feb 12, 2007 | 02:01 PM
freight400's Avatar
freight400
After playing around with this DVD-Audio thing for a week or so, I think I have finally figured it out. I am by far no expert, but there are actually a couple of solutions out on the internet, so I will try to explain each.
The majority of the information came from the TL forum on acurazine.
Solution 1 and 2, I used strictly mac software.
Solution 3 is a combination of mac and windows software through Parallels for mac.
Solution 1:
This is the one we have we have discussed earlier using Toast. The issue with Toast is that the files are burned into the video file of the DVD, akin to watching a DVD with sound only.
Solution 2:
Convert songs to .flac files, using Switch http://www.nch.com.au/switch/plus.html
Of these converted files, create an .iso image. I used DVD-Audiofile, it is free on internet.
Using Toast COPY function, drag the .iso file into Toast, then Burn DVD
This Solution worked fine for a while, but half way through disc, the disc stopped reading, back to the drawing board.
Solution 3:
Convert files to .flac in mac
Move files to Windows in parallels
Drag files to program DVD-Audosolo, different from DVD-Audiofile above http://www.cirlinca.com/products.htm
Burn disc according to instructions.
This solution has worked on the test discs I have created so far. I was able to create a 28,000 megabit disc, about 4 albums
If you have music purchased from the itunes store, you will need to remove the DRM from the song to convert. The best way to do this is to burn a regular CD then import it back into itunes. DRMDumpster automates this process for you using a CD R/W disc. I set mine up before going to work and when I get home, they are done.
Old Feb 12, 2007 | 06:05 PM
kaewen's Avatar
kaewen
hi freight!
thanks for the info. will try it when i have the time
Old Jun 3, 2008 | 03:53 PM
G Star's Avatar
G Star
I know this thread is over a year old
I know most posters in this thread have probably died
but...
is it possible to get some play time in the 06 ML by burning wav files onto a DVD-R?
whlkev
Mar 6, 2009 04:03 PM
3alwi
Jul 10, 2008 06:36 AM
james1017
Jun 30, 2006 03:44 AM
DRIVEN1
Feb 1, 2006 08:39 PM
