phone modification? Can't find
Hi, first timer here. I have the 300 AWD and followed the instructions to modify the NAV to allow for input while driving. HOWEVER, is there a thread on how to modify the phone so that you can enter either address book numbers of phone numbers while moving. I couldn't find that.
Thanks in advance,
Jim
Thanks in advance,
Jim
Jim,
Here's the link for your phone problem.
https://www.clublexus.com/forums/sho...8&page=3&pp=15
I completed it last week. You can dial and access phone book while in motion as well as let your passenger watch the dvd.
How did you bypass the Nav?
thx.
thx.
So, only rewiring works on the phone modification? I am too inept to to that. However, to do the NAV, hit menu, volume, then touch the upper left speaker, then the lower left corner, then the speaker again and then the same lower corner. A new screen should come up with the override option. Keep in mind that it will need to be redone each time you turn off the ignition.
Jim
Jim
Kendig
Aug 13, 2011 12:42 PM
rtanouye
GX - 1st Gen (2003-2009)
Mar 2, 2006 01:37 PM
brn2rnjk1
Aug 1, 2005 04:39 AM
