test fitting 20s......tech session
Old Jun 27, 2005 | 12:01 AM
JohnsRX's Avatar
JohnsRX
Default test fitting 20s......tech session
friend try to be the first in taiwan to have rims on the new 430. No one has done it yet.
20x10 with offset 30 dont fit so far, serious rubbing issue with 285/30/20 tires.
Looking at rims with 35 or higher offset right now. Will report status as we go along.
New 430 got some serious brakes:
Nice looking M3s are everywhere in Taipei:
Old Jun 27, 2005 | 02:15 AM
rominl's Avatar
rominl
exclusive matchup
try to get 20x10 +40 or +42, i think that's good starting point. i think even 35 might be too close, might still rub a bit, especially if you have 285
Old Jun 27, 2005 | 02:29 AM
JohnsRX's Avatar
JohnsRX
thank u so much, will get it right this time.
Old Jun 27, 2005 | 08:02 AM
LexFather
Guest
Posts: n/a
Keep up updated! Look at the size of the front brakes
Old Jun 27, 2005 | 09:39 AM
nysupraman's Avatar
nysupraman
thanks so much for sharing (unlike some secretive people on this board) , keep on!
Old Jun 27, 2005 | 12:36 PM
Chigga's Avatar
Chigga
your friend is HARDCORE! and he's gotta be a huge baller, how much GS430 goes for now? $3-something million NTD?
20"s in Taiwan, damn! where does he live? my cousin bent like 2 18"s on his Impreza GT and he lives in Taipei.
Old Jun 27, 2005 | 01:40 PM
rominl's Avatar
rominl
exclusive matchup
no problem. i am not that good in the 3gs offset setup at this point neither. just from what i read the setup is very close that on the 2gs. since i know relatively more on the 2gs so i just mentioned about what i know
Old Jun 27, 2005 | 04:13 PM
SoCalSC4's Avatar
SoCalSC4
When I was at the dealer a month ago, I did notice that the GS430 has bigger OE front brakes than the GS330.
They resemble Supra calipers. Do you know what the X-factor is? (the amount of overhang the caliper has from the rotor hat/wheel mounting surface?)
Old Jun 27, 2005 | 07:45 PM
JohnsRX's Avatar
JohnsRX
actually, no one i know, including myself has less than 19s in Taipei. The roads here are actually better than L.A in most respects, since speed is usually low here, bent rims dont occur too often. The 430 is about 3 million NT, or a little less than $US100k here.
Old Jun 27, 2005 | 07:47 PM
JohnsRX's Avatar
JohnsRX
sorry, no. But the caliper itself look bigger than the old 430.
Old Jun 27, 2005 | 09:59 PM
rominl's Avatar
rominl
exclusive matchup
definitely bigger, the 2gs430/300 has the same brakes as that on the 3gs300 i believe. and the brakes on the new 3gs430, i don't think they are supra tt units. they don't look the same
Old Jun 27, 2005 | 10:53 PM
blacksc400's Avatar
blacksc400
Car Chat Moderator
I would not want to roll 20' back in TW!! The roads there are just like driving Rallys!!!
Good luck keep them good for a month!
Old Jun 28, 2005 | 12:18 AM
JohnsRX's Avatar
JohnsRX
tell that to the many people here who has 22s!!!
Old Jun 28, 2005 | 06:54 PM
JKashat's Avatar
JKashat
I have all chrome Davin Revolution 6.1's (spinners) in 20x8.5 (+32) and 20x9.5 (+42). The rears sit just about perfect, and the fronts sticks out a little too much (about a 1/4 inch). I would mill the fronts down a bit (another 6mm), but then the spokes would not clear the GS 430's large front calipers. The rears fit perfect (w/o a drop). If you are gonna lower it, than go with 20x8.5 +38 front & 20x9.5 +45 rear. That would be perfect.
Old Jun 28, 2005 | 08:16 PM
LexFather
Guest
Posts: n/a
Correct, I would say they are in size to the 4 caliper units used in the LS 400/430.
