Driver side air servo motor
Decided to scan it with techstream, no DTC's leading to the servos, thinking that the cabin radiator might be clogged up. I ran the servos separately through the computer and I did hear a faint noise so I'm pretty sure the servo is operational. Also what I found out is that the servomotor values for driver and passenger sides seem to be flipped, so when you are blasting full heat the D (driver) servo is showing values around 100 (from 0-255) and P (passenger) servo is showing values around 5 (from 0-255). Did the recalibration as well and nothing changed. This is a heads up for anyone having the same issue in the future, just changing your temp from HI to LO is not enough to diagnose a faulty servomotor since the passenger side and middle ones are way louder than the driver side.
yardbird88
RX - 4th Gen (2016-2022)
May 4, 2025 04:45 PM
micahacobb
Feb 15, 2023 09:46 AM
