“Check sonar” warning
Old Sep 28, 2025 | 02:32 PM
e-man's Avatar
e-man
Default “Check sonar” warning
Hey guys. I’m getting a “check sonar” warning on my NAV screen. It is coming from the front park assist sensors. I’m pretty sure it’s either the middle left or middle right one because the outer two front sensors seem to be working just fine. Obviously I can turn off the parking sensors from the control panel, but then I lose all of them, including the rear ones. Is there a way to disable the problematic sensor?
Old Dec 28, 2025 | 11:45 AM
md2009's Avatar
md2009
10th Gear
I have the same issue after changing the sensors multiple times I was told by a Lexus tech that the wiring harness for the sonars go bad and it's most likely that one of the wires has deteriorated.
Old Jan 9, 2026 | 11:30 PM
NormzGS350's Avatar
NormzGS350
Default Toyota TechStream
Is it possible to check the status of each sensor in Toyota TechStream? Should get you a more definitive answer.
cmat
Dec 11, 2018 05:51 AM
atoyota
May 31, 2014 07:31 PM
jarm
Aug 26, 2012 01:05 PM
Rash
Feb 25, 2007 09:48 AM
timoc42
Jan 27, 2006 02:39 PM
